Question about Water Heaters
I have a vokera boiler and the fault that flashes up is 07. then nothing works till it clicks back on
    Champion:
  • 248 Answers
Refere to manual sounds like overheat stat call expert
Posted on Oct 11, 2009
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Check internal fuse un main circut board
Sep 29, 2013 | Water Heaters
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
Vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Mar 14, 2009 | Water Heaters
Vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Feb 20, 2009 | Water Heaters
Vokera linea combiboiler error code CO
It's got nothing to do with carbon monoxide. CO means the boiler is in combustion test mode, that's all (and in this case -- long since fixed, I imagine, but other people will no doubt find this page in the future -- failing). Vokera could probably have made this clearer, but hey.
Dec 23, 2008 | Water Heaters
How to bleed a vokera syntesi combination boiler
I think you mean your boiler needs pressurising firstly connect hose hand tight open the non return valve normally teed into a 22mm pipe then flick the valve lever on the cold supply quick little bursts till you reach your required pressure best of luck
Nov 15, 2008 | Water Heaters
Water Heaters Logo
176 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
