Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
I was told my Toyostove Laser 72 stove needs to be cleaned. Can i do this myself and what do I do.
  • 22 Answers
Throw your laser 72 out!
They don't make parts for them anymore.
Posted on Jan 30, 2015
  • 61 Answers
I would recomend having a qualified technican service your Toyo.
It IS possible to clean it yourself, but you will want to do it during a time that you aren't needing the heater to keep the space warm.
Certain parts can be hard to tell if they are working as they should if you aren't familar with what you're looking at.
With proper service, your Toyo will operate efficently, and likely last for a long time.
_Helping Hands Services_
- Fairbanks, Alaska -
Posted on Oct 27, 2009
When i turn on my monitor it read E-08. What does that mean?
If it's a Toyo stove it means blower motor. It may just need cleaned or might need to be replaced.
Mar 05, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a toyostove laser 30 and it leaks at the bottom (there is no parts or stove damage) and it does not burn cleanly. I will smell terrible oil fumes after every heating cycle. What should I do? I have...
If you have a A model Laser 30 you will have to take the stove apart to get to the fuel sump pipe. 9/16 wrench will tighten it. If it's a B model you can reach it on the lower right side of the heater.
Tom
Sep 25, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Low heat output. Older Laser 72. Does something
It's likely that the burner mat has came loose or it has a lot of carbon buildup in the burner. Look at the flame when the heater is on. It should be mostly blue with slight yellow tips. You might need to clean the fuel nozzle also. You can remove the fuel pipe where it connects to the burner and use a piece of wire or an allen wrench that will fit in the nozzle that goes into the burner to remove any carbon that may have built up. You can also clean the burner but don't destroy the mat in the bottom. You can find the owner's manual at toyostove.com and it will give you some more things to clean.
Apr 17, 2010 | Rinnai Toyostove Direct Vent Heater:...
Toyo Stove ventilation
Alaska Cat,
No this is not right. You can remove the air hose for a short time until you can get another part, i.e., new flue pipe. The stove tech should have told you he would be back with a new part. As far as the igniter is concerned it could be replaced without removing the heater. Now, if you had flooded the unit trying to start it many times your mechanic might have had to take the unit out just to be able to clean it completely.
Stay warm,
Tom Hawkins
hawkins111@gci.net
Apr 01, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo 55, igniter gets hardened build-up
Gartyl,
Your Laser 55 burner mat has erroded away. The fuel is pooling someplace in the burner rather than spreading smoothly over the bottom. The stuff on the igniter may be hardened carbon from a poor flame. Bottom line is some burner work. A new mat, ring and cleaning the burner air holes is in order. Don't be surprised if the heat chamber is cracked beyond repair when you get it off. NOW for the bad news. The Laser 55 and 72 are older heaters. You will find just about all the electrical parts are going to be hard to find. They are no longer being made. Your 55 will be able to use the newer 56 blower, mat and burner ring. You will also be able to use the heat element off a 56 as well. If there is a problem with the fuel pump causing your poor flame you will be out of luck.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 02, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
CL code
The stove is doing self cleaning I believe ;) It will show cl and then 10 down to 1 and it will restart.
Oct 28, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 73 ee 2
try this site....
http://www.rural-energy.com/publications/catalog/category/101
How long has it been since you've cleaned your stove? If it's been a while the flame sensor (the part with the metal rod) may be building up a chain of carbon blocking the igniter from igniting the flame. A temp fix is to jiggle the sssensor but what is needed is a cleaning. Also you may need a new burner ring. That solved my problem last winter.
Oct 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove 72 won't go on high.
Replacing the burner ring (center piece?) will do wonders. When it's warped the stove won't work properly.
Jul 22, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove l73
Try cleaning the fan blades, etc. Does the blower stop after a while and not start again? If there is no ignite at all, could you need to clean your stove. Especially the heat pot?
May 01, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 72 exhaust blower noise
the combustion blower sucks in clean air so it has no place in the exhaust stream. hence no carbon build up. the blades of it look like a vacuum disk on a vacuum cleaner. if the fan was recently rebuilt, make sure of the placement of the bushings. if one is misplaced the fan will rub on its housing and make all kinds of racket.
Dec 16, 2007 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
478 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
