Question about HP LaserJet 3055 All-In-One Printer
Error 49A What does this mean? - HP LaserJet 3055 All-In-One Printer
    Problem Solver:
  • 13 Answers
There is a firmware upgrade to solve some of the quirky issues such as the 49.A### error codes associated with this and other MFP devices. Please visit hp.com and download the utility to perform the upgrade. This is free and will fix most issues associated with the 49 error.
Posted on Oct 27, 2009
  • 404 Answers
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Posted on Oct 05, 2009
I specifically need an answer to this question. How do I "backprobe J3D03 (Circuit 633, brn/wht wire) at PCM with voltmeter." according to 98-T-49A
You need a pin out chart of the PCM connectors an a wiring diagram ! You need T pins to back probe the terminals . What make ,model an year vehicle . This just an example of a connector pin out chart ! What Saturn do you have ? It sounds more like a crank sensor then a cam sensor ,whit the way it's running ! I mite be able to help , I have Saturn service info an all GM 1996 to 2009
Labscope cam sensor test
May 16, 2015 | Cars & Trucks
Where's the IndIcator relay swItch on a daewoo lanos
Here is some extra information on replacing the Daewoo Lanos indicator / hazard lights relay. Open the driver door, on the side of the dashboard there is an access panel. Flip it open with a screwdriver.
Now you can pull out a violet connector block. The relay is plugged into this block, it is green. You can just pull it out of the connector block and replace it by a new one. The part number is 96312545, and it has three pins, numbered 31, 49 and 49A.
Other specifications: 12V 2/4x21W. It is made by Daewoo / DECO. The same type of relay is used in the Daewoo Matiz. I picked up a used relay from an old Matiz for 2 euros and the indicator/hazard lights work like
a charm again. The whole replacement took about 2 minutes, but it took me days to get the used part. Probably other relays with these three pins will work too: google for "31 49 49A". Hope this is useful to other people who run into problems with the Daewoo Lanos indicator lights!
May 29, 2012 | Daewoo Cars & Trucks
Have hella 24v flasher unit with pins 30,49 and 49a how do i connect it
pin 30 is from your power source
pins 49 and 49a goto the lights themselves
Feb 02, 2010 | 1997 Land Rover Defender 90
Cannot do installation of cartridge 13a into my printer
You should use a 49a cartridge. Q4959A or Q4959X.
Gerrit Jan
Oct 29, 2009 | HP LaserJet 1320n Printer
New 49A cartridge prints unevenly with blank spots
new toner faulty.is this a geniune cartridge??
Jun 30, 2009 | HP LaserJet 1320 Printer
2001 daewoo lanos, blinkers dont work
May 19, 2009 | 2001 Daewoo Lanos
Indicators not working for a daewoo lanos 1998 model.
If both indicators and hazard lights are not working, probably the indicator relay is broken.
Jan 18, 2009 | Daewoo Lanos Cars & Trucks
Problem in ms excel
right click on the file and click on properties, then uncheck the "read only" box. you need to also check if you have the admin rights to open the file since it could be the cause why you're getting that error. if it will still not allow you to open it, ask the author of the file to provide you the rights.
hope this'll help you and just ask me if you'll have other concern.
ciao!
Jul 10, 2008 | Microsoft Computers & Internet
HP LaserJet 3055 All-In-One Printer Logo
1,237 people viewed this question
Seeker5211
Seeker5211
