Set is connected to a DirectV satellite box. When the system is turned on, the TV starts up normally but then shuts off after 12-15 seconds. The pilot light on the front stays on, but there is no picture or sound. Model # is 27PT543s37A
Your technician indicated there was a problem in the "horizontal deflection circuit" and that a local TV terch s/b able to fix it. I have a tech visit scheduled for Thursday.
Posted on Oct 06, 2009
Can I as subscriber to direct tv can I use a mobile satellite dish
DIRECTV FOR TRAVELERS
https://www.directv.com/DTVAPP/content/contentPage.jsp?assetId=P6730097
With DIRECTV's cutting-edge mobile service, you can enjoy your favorite TV ... Contact one of the following distributors to order your mobile satellite receiver and ...
How to SetUp Your DirecTV On the Road in Your RV ' Roadtreking Blog
roadtreking.com/how-to-take-directv-on-road/ Jun 20, 2013 - Learn how easily you can set up DirectTV in your RV. ... You also have a permanently installed satellite dish at your house, probably ... The trick to making your system portable is to bring the box and a second dish on a tripod, ... First, set up your tripod so the mast is perpendicular - use a torpedo level for ...
A Guide to RV Antennas for Satellite Internet & TV - Reviews.org
www.reviews.org/internet-service/rv-satellite-internet-and-tv-antennas/ Getting satellite internet and TV on your RV isn't as hard as you may think. ... DISH and DIRECTV do not actually offer an antenna (dish) that can be used on the ... a proprietary dish for your mobile internet unless you pair DIRECTV with an ...
How to Set Up a Portable DirecTV Satellite Dish ' eBay
www.ebay.com/gds/How-to-Set-Up-a-Portable-DirecTV-Satellite-Dish-/.../g.html Before obtaining a portable DirecTV satellite dish, purchase a subscription. Subscribers who already have DirecTV installed at a residence can use a part-time ...
direct tv can use mobile satellite dish Google Search
Sep 25, 2017 | Televison & Video
Can i program lg magic remote to work with direct tv box
If your LG TV came with the IR blaster cable you will need to set one of the sensors in front of the sensor on your DirecTV box. Then go to your TV setting and select Video Input and Select the Input Port that your DirecTV box is hooked to. (In my case HDMI1). Then you will select that you are trying to sync your Service Provider and it will give you a list of device manufacturers. Select DirecTV limited and it will start to give you codes to try. You test these by trying the channel button up or down. If the channel changes you have found your code and you will click on "Yes" and you are ready to control. The "Guide" button will now bring up the DirecTV Guide and you no longer need the DirecTV remote.
Jun 05, 2012 | LG Televison & Video
Intermittent audio loss with 42 inch 2007 Sharp HD( not plasma) TV. Happens 2-4 times/hour for a second or two during most HD programs. It has gotten more frequent over the past month. We have...
Are you running the sound directly from the DirecTV box to the Onkyo reciever? or is it routed through the TV first? Personally if you have it routed through the TV you are losing out on true 5.1 surround. To ge that you need to have the DirecTV box connected via optical or digital output (orange connector) to your Onkyo amplifier. If you need further assistance please email me at tvtek(at)msn.com
Nov 17, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Trying to find out what my tvs settings should be on to hook up m
Have you tried channel 3 or the video input channels.
The Tv only needs the one channel that the signal from the box is sent on.
All the viewing channels will be changed through the satellite box.
May 11, 2009 | LG Televison & Video
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
Initial set up w/directv
First, I hope you got an extended warranty with that. Otherwise it's a disposable T.V. after your warranty is up.NO PARTS are available. Hope it lasts more than a year..if your lucky. You need to change the channels on the direct tv box. Don't scan the t.v. You need the t.v. on channel 3 or video input that the box is connected to. Do you have hdmi cables? How did you hook the box to the T.V.? Did you read your book that came with the T.V. about hooking it up with a cable box??? Same thing as Direct T.V. box. That should show exactly how to connect. More info will help dtermind your problem.
Dec 05, 2008 | Dynex DX-LCD37 TV
2 dtv boxes one Satellite
you need to install a multiswitch so you can run more than 2 coax cables from your dish
Jun 24, 2008 | Directv (DWO2-10024)
No Audio
1. Make sure you have connected the cables from audio OUT on the Directv box to the audio IN on TV input 3 and have selected the correct source on the TV.
2. Many sat boxes have an audio volume control. Select the satellite box on the Directv remote and turn up the box's volume.
Hope this helps.:)
Apr 01, 2008 | JVC AV-56WP30 56" Rear Projection...
Cant get sound from speakers
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Feb 03, 2008 | Audio Players & Recorders
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
