Question about Microsoft Windows XP Professional for PC
Windows start up
Is there a utility to view and change windows start up programs? I want to remove few programs to speed up windows boot.
    President:
  • 317 Answers
Start>Run
Type "msconfig"
Click the Startup tab
Uncheck what you don't need
Posted on Dec 22, 2007
    Problem Solver:
  • 9 Answers
Go to Start -> run 7 type msconfig.
Go to the startup tab and you can unclick all programs you do not need in your startup.
Hope this helps.
Thanks & Good luck!
My computer wont let me sign in
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Mar 22, 2013 | Computers & Internet
Tip
Speed up Windows Boot Time
Many people ask about Windows boot times and how to make your boot time shorter. This is a quick tip about how to eliminate some of the unneeded or unnecessary items from your Windows XP/Vista/7 boot time.
First, make sure that you are logged in with Administrator privileges.
Next, Click the Start Button (Windows logo button in Vista and 7) and then click Run. (In Vista and 7 you can just type into the search box under the Start button). Type "msconfig" (without the quote marks) and then click OK or press enter.
In the System Configuration Utility, click the Startup Tab and deselect all of the items. In the Services tab, check the box for Hide all Microsoft Services and then disable all the other items.
Now, you will need to reboot your computer after applying those changes and time the boot up. If the time is dramatically faster, then it is likely that one or more of the items in the Startup Utility are causing the lag in boot time.
Go back into MSCONFIG and go to the services tab. Re-Check a few items, apply the settings and reboot. MAKE SURE TO WRITE DOWN WHICH ITEMS YOU'VE RE-CHECKED. Now time the boot up process again. Continue this process of re-booting, timing, going into msconfig and checking a few items back, and rebooting and timing until you find the items that add significant time to your boot up process.
Once you've found those items that are adding time to your boot time, you will need to determine if the item is one you can leave unchecked - or if it is something that you may need to run during startup. If it is a critical program, you can try to get it to boot quicker by reinstalling the program or seeing if an update to the program will fix the issue.
Hope this information is useful!
on Nov 20, 2011 | Microsoft Computers & Internet
Tip
Tips To Make Your PC Boot Up Faster
If your pc is taking ages to start up , then follow this advise to speed things along and get you going faster.
1. Uninstall Old Programs and Stop Unwanted Services From Starting.
The main culprit making a PC slow to boot is programs. If you have programs installed on your computer that you are no longer using , you should remove them.
These programs often have background processes running which not only uses your RAM but also takes time to load at start up.
A useful program I found is Tune Up Utilities. This program has a feature called start up manager which will allow you to stop unwanted programs from starting up when you turn on your PC. Not only that , but the software also identifies programs and processes which you should keep running. A free trail version is available HERE.
You can also do this in Windows Vista and Windows 7 by going to run in your start screen and typing in msconfig. Then go to the start up tab and deselect everything you don't want to have start when you start your computer.
If your run command is not visible , go to command prompt and type in msconfig.
2. Windows loading screen
You know that page with the animation? That takes forever right? You can actually remove it without much trouble and it will save about 10 seconds on your start up time. Here's what you do.
Go to run in your start screen and type in msconfig.
Go to the boot tab and select "noguiboot" checkbox.
This will cut the animation getting the computer to start faster. If you have a duel boot system , you can also set the timeout for that menu by making the timeout 3 seconds instead of 30 seconds.
3. Defrag and clean the Registry
Download a free program called CCleaner (HERE) and install it. This program will remove invalid registry entries. This will mean less time that the computer is looking through registry keys and thus improved start up and system performance. Just click "run cleaner" and it will automatically search for and remove invalid keys.
You may also want to defragment the registry. Open Tune Up Utilities and select all functions under the first window called "maintain system" and select "defragment registry".
This will also help a little for system performance and start up time.
4. Edit Your Bios
The bios by default contain some options that are redundant and can be switched off to save on start up time. For instance :
  • Make your first boot device your hard drive.
  • Select Quick boot or "do not check memory"
  • If you are using a graphics card , disable the on board as it's only using memory.
Following these few steps should save you about 30-45 seconds on start up and improve overall system performance.
Please rate this solution if you found it to be of help.
Stephan
on Feb 02, 2010 | Computers & Internet
I do not know my password to start windows on my laptop
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Feb 08, 2013 | Computers & Internet
Change password for wndows start up
Oct 20, 2012 | Dell OptiPlex GX260 PC Desktop
Tip
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
on Jan 03, 2010 | Computers & Internet
Forgot password when it starts up
The experience forgot admin windows password happened to me few days ago. And I searched in the Internet to find the solution. Then I found a windows password reset tool called Windows Password Reset have a good evaluation.
I tried it as the steps:
Step1:Download and install Windows Password Reset from http://www.windowspasswordreset.net
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in my newly created CD and remove my Windows Password.
It really great help to me reset windows admin password.
Hope it help you too.
Jul 28, 2012 | Dell Latitude C610/C600 Notebook
How do i delete my sbc global.net account
If you no longer utilize AT&T Internet services and want to uninstall the program, it's not hard to do. This will free up room on your hard drive. There are several approaches you can take to remove all traces of AT&T Internet on your computer.
Removing the software using Uninstall Manager
1.Click the desktop "Start" menu.
2.Select the "All Programs" folder.
3.Click the "AT&T Yahoo! High Speed Internet" folder, then click "AT&T Yahoo! Uninstall Manager" or "Uninstall AT&T Yahoo! Applications." The AT&T uninstall manager will be launched. Click "Next."
4.Check all AT&T related programs that you want uninstalled, or click "Select All."
5.Click "Uninstall" or "Next" to begin uninstallation.
Remove the software manually
1.Select the "Control Panel" from the desktop Start menu in Windows XP or 2000.
2.Click "Add or Remove Programs" in Windows XP and 2000, or "Uninstall a Program" in Windows Vista and 7.
3.Click "SBC Yahoo DSL Utilities" and click "Change/Remove" or "Uninstall/Change." Your computer will uninstall the software.
4.Go back to the "Add or Remove Programs/Uninstall or Change a Program" screen and remove all additional programs, one at a time: SBC Internet Mail, SBC Yahoo! Messenger, SBC Yahoo! Parental Controls, Yahoo! Companion, Yahoo! Login, Yahoo! Messenger Explorer Bar, SBC Yahoo! Dial, SBC Yahoo! DSL Utilities, SBC Yahoo! DSL and SBC Connection Manager. Windows 2000 users should also uninstall BroadJump Client foundation.
Sep 07, 2011 | Computers & Internet
I dont konw how to turn off deleting prefatch data in tuneup utilties 2011
TuneUp utilities does not seem to have an option to delete prefetch data, however, you can view all settings in the options menu.
What you may be seeing is simply a notification within TuneUp Utilities that the prefetch data was deleted either by another program or mistakenly by you.
The prefetcher in Windows basically speeds up the computer boot process and start up program speeds. Windows will rebuild this information automatically on each reboot and program start up, so, over time, you will see the problem corrected.
-G33k
Apr 15, 2011 | Microsoft Windows 7 Ultimate for PC
Computer boot screen slow?
Do 1
6. Restart
Do 2
2. Click Run
Do 3
5. Click Apply
Do 4
Do 5
1. Click on Start
2. Click Run
5. Click Stop
6. Click OK
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
Microsoft Windows XP Professional for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
