Question about Thermador SMW272 Electric Double Oven
The panel that shows the tempature and timer information is not longer bright enough for me to see. How can we fix that
  • 725 Answers
This is a simple repair! You simply need a new control panel. Call us as soon as you get a chance and we will give you the cost of this part and we have next day air shipping so your Thermador oven can be repaired this week. 972-859-0929. We hope this answers your question and we look forward to working with you.
Posted on Oct 05, 2009
Buzzing and f2 showing on display panel
The F2 error code means that the over overheated by at least 100 degrees above the tempature that was set at the time. The usual reason the oven would over heat by so much is a defective oven tempature sensor and the sensor would need to be tested to see if is the problem to test the sensor it would need to disconnected from the wiring to it and measure the amount of ohms of resistiance AT ROOM TEMPATURE when the oven is off and cool. At room temp. the the meter used to check the sensor should display between 1060-1100 ohms,if the number is vastly different that 1060-1100 at room tempature the sensor is defiently bad and should be replaced. This is what the sensor looks like oldtech2332_129.jpg
it will be inside of the oven chamber and again to properly check it the wiring should be unplugged and the meter leads should be placed into the plug at the end of the sensor to measure the ohms
GENE
Oct 10, 2011 | Amana AOCS3040 Electric Single Oven
All the functions works well, but after a few minutes the oven stops and display "F2". The screen is well, the temperature selector, timer, clock, all works well but the oven stops functioning
GENE
Oct 09, 2011 | Whirlpool RBS275PD Electric Single Oven
GR448LXPS ERROR CODE E2F3
The F3-E2 error code means that the heated well above the setting the tempature was set at. The usual reason the oven would over heat by so much is a defective oven tempature sensor and the sensor would need to be tested to see if is the problem to test the sensor it would need to disconnected from the wiring to it and measure the amount of ohms of resistiance AT ROOM TEMPATURE when the oven is off and cool. At room temp. the the meter used to check the sensor should display between 1060-1100 ohms,if the number is vastly different that 1060-1100 at room tempature the sensor is defiently bad and should be replaced. This is what the sensor looks like oldtech2332_129.jpg
it will be inside of the oven chamber and again to properly check it the wiring should be unplugged and the meter leads should be placed into the plug at the end of the sensor to measure the ohms.
If after checking the sensor if its within the range of 1060-1100 ohms at room tempature the problem is going to be the control board.
I hope i have been able to help ya fix your oven,
Oct 08, 2011 | Whirlpool Ovens
Timer shows F30
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Nov 04, 2010 | Kenmore Ovens
I need to know to set the tempature on my jenn air range oven this is a push button ove n
i decided not to try to fix it i think i would have to buy a complete panel, to fix it that would cost nearly as much as a new stove
Jan 29, 2010 | Ovens
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
Oven shows temperautre but does not get very hot
most likley you have a burned out elements, the tempature is probably just the temp you are selcting, if I am incorrect in the temp, ie, it does show the temp as oven heats, then the most likley problem is the tempature sensor is faulty or wiring to the sensor is faulty.
Apr 10, 2009 | Ovens
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
Thermador SMW272 Electric Double Oven Logo
137 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
