Question about HP LaserJet P3005 Printer
High pitch squealing coming from one of the rollers
Whenever we print there is high pitch squeal coming from one of the rollers. I think it is from bottom roller you can see when you open the back paper door. It happens when printing from either tray. We have had this printer for over 1 year, have not installed any new parts and this just started happening recently. Does it need to be oiled? Replaced? Cleaned? If so How do we do it?
Thanks for your help.
    Problem Solver:
  • 6 Answers
Replace the gear under the fuser this is the part # RU5-0957-000
Posted on Oct 09, 2009
  • 404 Answers
Hi! I will be glad to assist you.. here is the link to guide you to this issue.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00744954/c00744954.pdf
Posted on Oct 05, 2009
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
2004 GMC Yukon Denali - Squealing within the interior
high pitch squeel usually comes from the cambelt
Jul 24, 2008 | 2002 GMC Yukon XL
My Hp 1200 laser printer makes a high pitched squealing noise and I have to pull the plug out to stop it.
The fuser is the part of the printer that heats the toner to the paper. turn the printer around and open the back cover. You should see a long black bar with green clips on either side to release a paper jam. There may also be rollers in there. Make sure there is no debris in the fuser, and that those clips are in the functioning position (usually down). If the fuser is removable, which I don't think it is in this model, take it out and then reinstall it. Then give it a shot. Usually though high pitched squeal is a toner cartridge thing. If you are using reman cartridges try a new (actual hp) cartridge from office depot or staples.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
May 13, 2014 | HP LaserJet 1200 Printer
HIGH PITCHED dryer SQUEAL but clothes are drying...
Had same problem that went away after replacing each of the drum roller wheel/bearing assemblies. (repairclinic.com) Not the easiest of jobs removing & replacing the drum, but a lot cheaper than a new machine.
Nov 23, 2013 | Frigidaire Washing Machines
I have a high pitch squeal from 1998 buick 3.8, told it was water pump, changed, still same, changed belt due to squeal, but still have same sound. Turned on n off a/c comp but did not change anything....
i have the same problem, changed the alternator, pulley and all that, it happened after i had the intake changed out due to the egr problem, if yours hasn't been changed id look into it before it goes, better sooner than later sorta things...
Feb 15, 2011 | 1998 Buick Park Avenue
1994 nissan pickup high pitch squeal when driving
it could be the engine belt or the brakes are bad listen to where it coming from and you will know which you have to change
Aug 18, 2009 | 1994 Nissan Pickup
High pitch squeal
IT IS MORE THAN LIKELY A STUCK DRUM ROLLER OR IDLER PULLEY. I HAVE SEEN IN WORST CASE SCENARIOS WHERE IT HAS BEEN THE MOTOR ITSELF WHEN SUBJUCTED TO LOTS OF LINT AND DUST FROM PLUGGED VENTING. I WOULD CHECK THE FIRST TWO AS THEY ARE THE MOST COMMON. DO NOT OIL THEM.
Dec 28, 2008 | Maytag MDE2600 Electric Dryer
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
HP LaserJet P3005 Printer Logo
373 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
