Question about Maytag Neptune FAV6800AW Top Load Washer
Hello, can you help with some ideas on why my Maytag Neptune Top Load FAV6800 will not finish a cycle? The washer has been sitting for about 7 months not being used in storage while I was moving. I recently hooked it up. I can usually get it to Wash then Rinse (but not all the time), but I can not get it it Spin. The motor sounds like it is going to ramp up(for about 5-10 seconds) and start to Spin, but then turns off. Sometime this same problem does this with the Rinse cycle as well (the cycle ramps up like it is going to Rinse), then turns off. I do not get any error codes on the front
  • 335 Answers
Hello novak_t18,
With a empty Wash Basket if you do a Spin Only cycle will it start and complete?
If you can get into Service Mode try the Quick Spin Test on page 14 of the SM. Do you pass that test?
Lets start there and see what we get. Post back if you have any questions. If we need to pull off the front cover do you want to continue troubleshooting?
If you can get into service mode and step thru the diagnostic codes that may be of some help. If you can review that process in the SM on page 25 Display Diagnostic Codes and step thru the diag codes and record.
The Service Manual for reference. Sears Parts Direct for reference.
Thank you for posting your model type even though you are in the FAV6800AW forum. I wish this board would prompt forum members for the model number for that and the first two digits of the Serial Number
I’m an owner like you not a repair tech and that would help me. Thank you again for good solid info. Rich
Posted on Oct 05, 2009
  • dh1200s
    dh1200s Oct 06, 2009
    I think this may be happening with your machine. The info is taken from the MAH3000 Service Manual. I feel the FAV6800AW/FAV9800AW Motor Control/Motor are close in design. Try checking for corrosion issues on the Motor Tach connectors and Motor Control reseating all those connectors.
    “”Another purpose of the motor control is to monitor the drive motor speed through a tachometer
    circuit linking the motor control board to a tachometer on the drive motor. This is a 3-wire circuit comprised of a Black, Blue and White wire harness. Failure of this circuit will cause the motor to start jerking in place or accelerate rapidly for up to 5 seconds. This occurs whenever the tachometer in the drive motor is trying to locate the proper shutter and sensor sequence. For example, if the tachometer signal is lost from the motor control to the machine control just prior to spin, the motor will ramp up for 5 seconds then stop.””
How to access drain pump on maytag neptune FAV6800 top loader washer
The drain pump can be accessed by removing the rear panel and following the hose down
Jan 26, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer is very loud when in the spin cycle
I would ask Washerbearings.com and see if they have a bearing and seal kit already or if they can make one up for you for the FAV6800 top loaders.
Oct 19, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Neptune fav6800 top load washer all symtoms indicate the motor controller
If this is confirmed then you have to replace the controller unit. But since none of the symtoms were mentioned and if the there is no action or output from the controller you must replace the unit.
Nov 02, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800 model - We had major water damage to our basement due to the water over filling the tub. Would you be able to provide guidance on what the pressure switch looks like and how to...
Damon,
I can't post pics at this site got to this site http://forum.appliancepartspros.com/washer-repair/
Post your issue and I will help you.
Do you have the FAV6800A/FAV9800A SM? If not I can help you with that. We will need to go into Service Mode and look to see if the pressure switch transitions take place during the water fill cycle.
I assume if you pull the 120VAC power cord or hit the off key pad the machine will close the Water Inlet solenoids and stop the wash tub fill........Rich
Dec 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Getting dc error code in rinse cycle, 13 min.
See my Clutch Fix post. Anyone with basic mechanical skill sets can save there $1000 machine for low cost maintenance or Clutch pulley replacement.......Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
May 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Getting dc error code in rinse cycle, 13 min. before being done Have un-pluged and still getting code. Maytag FAV6800 LED washer, 5 years old.
Hello rdberg,
See this post Clutch Fix it has helped a few owners with the dC and uC unbalance errors with the FAV6800A and FAV9800A machines. You have a very common problem with a Clutch malfunction. The first part of the post has to do with the nuts and bolts of disassembly and Clutch maintenance or replacement of the Clutch Pulley.
In the last part of the post I go into just how to check the One-Way Rollers clutches to verify that are locking up. If they don’t this results in tumbler movement on Wash Basket spin up and the unbalance errors. If you are handy and have some basic hand tools you can get your machine back in service at low cost.
Post back if you have questions…..Rich
Mar 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
98 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
