Question about Gateway GT4016 Desktop PC
When I turn the power on it starts up, then fan slows down till it shuts off by itself. Is this a power pack supply problem?
  • kyle65 Oct 08, 2009
    It doe's it fast, It powers up and the fan over the processor starts to spin and picks up speed. The computer starts to boot up, and it say's it didn't shut down correctly and start in safe mode than the xp screen starts up, at this point the fan is hardly running and the whole computer shuts down completely. thanks for your response.
  • mspanno May 11, 2010
    Does this happened suddenly or does it take awhile. Does it work after cooling for a few minutes? The usual problem is that the fan is bad on the power supply and it heats up until it the power supply goes into thermal shut down.
    Champion:
  • 204 Answers
I that the caps are bad on the motherboard. They are probably puffy and not flat like they should be.
Posted on Oct 07, 2009
    Problem Solver:
  • 15 Answers
No i think its power problem with ur SMPS. u can repaire or can buy new one its only upto 350 rupees
Posted on Oct 05, 2009
How to fix the HP Laptop are shutting down by itself
Hi Walter, The link below is a YouTube video showing how to fix your lap top shutting down by it self, Also there's videos down the right side of the link that may help as well, By the way instead of using a straw I'd undo the back..........CHEERS..
Don panic Is your laptop shutting off by itself or slowing down during use
May 11, 2016 | HP Pavilion dv9000z Notebook
Shuts down 2 seconds after powering on.
Don't know this exact server. But my guess it is either a heat issue or a power supply issue. Turn it on with the cover off. Check the CPU fan(s). If your CPU is getting too hot the system might be shutting down power to save it. If everything seems cool it might be the power supply I have seen it when the power supply fan goes out on the power supply and the caps inside start to sizzle. Voltage ramps up and fail.
Hope this helps.
Also, Something that has tripped me in the past. Make sure the power button is not stuck. I had a server that the power button stuck down and it would turn itself off. Took me 2 CPU fans and a power supply to figure that out. LOL
Oct 08, 2013 | HP ProLiant DL385 Server
Shut down dell dimesion 4600 because it was running slow and it wouldn't boot up again
If it was running slow and now nothing at all happens when you press the power button, your power supply has probably died. Be careful replacing a power supply, if you accidentally get into the power supply itself, even with it unplugged it could kill you. DO NOT TRY TO REPAIR POWER SUPPLIES EVER! They are cheap and easy to replace, however dell has proprietary power supplies so you can't just go pick up a new one at the store. You must contact dell and order a new one. Once you have the part spend the few dollars to have it installed by a professional. If you are getting some action when starting (sounds, lights, ect.) it could be any number of things, but judging by the slow down I would say overheating. Again spend a few dollars to have a professional look for signs of heat damage and replace and bad components (hopefully not your system board) and install a new fan or additional cooling methods to prevent in the future.
Sep 30, 2010 | Dell Dimension 4600 PC Desktop
Computer just turnoff suddenly
Could be one of two most common problems?
#1
Have you ever replaced the CPU Cooler (Heatsink/fan)?
CPU Cooler fan may be working, Heatsink dirty.
CPU is over-heating = mainboard turns off
Replace CPU Cooler
#2
Power Supply fan not working causing partial failure on 5volt or 12volt side.
Replace Power Supply
There are more causes but these are most common for short-time boot problems.
Another could be hard-drive, but that wouldn't shut system down like first two would.
Apr 04, 2010 | Sony VAIO PCV-W500GN1 PC Desktop
A/C starts up/Cools/Fan Slows, Unit Shuts down in 4 minutes
Ensure proper voltage to the unit. Check for overheated/damaged wires and/or connections in the control panel as well as at the fan motor and compressor.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
Initially, my fan would run fast and then slow. Then, it began to shut off frequently by itself; the monitor would state "monitor sleeping." Now, the CPU will not power on at all. Even after having a...
Fixing the problem would have been to change the fan when it started to fail. The bearings were probably going out and causing it to labor and slow down. When the fan quit altogether that was the big flashing warning sign "Do not run till you fix me" type of warning. CPU's develope tremendous amounts of heat. Without a fan there to cool it, it could have damaged something.
1. Get a new fan
2. Unplug all add on cards
3. Unplug hard drives, floppys and cdrom
The only thing that should be plugged into motherboard is the video and ram and keyboard. Unplug power supply for 1 minute. Make sure the power supply master switch on the back is on. Try to start the computer. If it starts then start connecting your drives back one at a time and any addon cards. If it doesn't start you may be looking at replacing motherboard or CPU. I've never seen an Intel CPU fail even from heat but there is a first for everything.
Dec 07, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Infocus in26 fan runs continually
The fan does run continuously on this projector however it should be running very very slow when the projector has completed it's lamp cool down routine.
The reason for this is that a portion of the switching power supply remains energized (running) when the projector is at rest. But as I mentioned it should run very slow in this state. If it remains running full blast then most likely the fan speed control chip is shorted which can cause fail 2 ways, either the fan 1. runs full
speed or 2. remains stalled (then the projector will go over-temp and shut itself down) I hope this answers you question.
Cheers
Dec 18, 2008 | InFocus IN26 Multimedia Projector
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
Fails to start
the problem is your fan may not have got proper power supply....the wire connecting the fan and power chord should be perfect....if there is a loose connection your fan may not get proper power supply and then it will not run.....this is the main probem.....just check the wire connection between the fan and power chord has been properly connected and there are no loose connections....i am a software engineer....and have experience in it....try this ...it will 100% solve your problem.......
Sep 19, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Gateway GT4016 Desktop PC Logo
173 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
