Question about Microwave Ovens
I have as yet to get the right answer and help for what I have ask for. I received 2 answers for detachable cords 1. for a motercycle 2. for electric meters etc. I need a detachable cordset for an Ultrex deep fryer, model #14022 the model number for the cord is #14099. A deep fryer nothing else. They still make the Ultrex deep fryer because it is on the internet. I just can't find the electrical cord detachable. If you cannot help me ok, but I paid $9.99 for help, for an elecrical detachable cord for an Ultrex nothing else. Thanks Bob
    President:
  • Microwave Ovens Master
  • 1,922 Answers
Hi:
Don't know the specs on your cord, but you can try Aubuchon Hardware at 1-800-431-2712 they have a universal repl cord 6' long with 1and 1/16" pin spacing for $6.99 part # 652573,hope it helps, couldn't trace your cords model #...dan
Posted on Oct 13, 2009
WHERE IS THE FUSE ON THOSE MODELS NN-SD277 MICROWAVE
If mounted on the wall above the range, this may be a 2-man job to remove, and the electrical repair may not be for DIYer. 1st ask "Why is fuse bad?" Usually the fuse is located with other electrical/electronic components behind the control panel. To access: unplug, remove MW from wall, remove bonnet (3-sided metal shroud), expose the electrical compartment on the right side, search for the fuse (usually 1 1/4 x 1/4D cylinder). Replacing the fuse may not be the final answer.
Nov 28, 2014 | Microwave Ovens
I have asked the question why do you keep asking the same questions and don't answer the question I'm asking
there is a ceramic safety fuse inside the unit,to access the control panel or to remove it you need to open the case up and remove the outer cover,careful the h.v. capacitor can hold a charge up to 2000 volts if not discharged
Oct 25, 2012 | Sharp R-820BK Microwave Convection Oven,...
I have a Westinghouse microwave WST3501 and need a longer electric cord..any suggestions ?
A person with electrical experience can splice in an added amount of cord, but I would not recommend any more cord than needed, since too long a cord can affect the current and possibly lead to overheating and damage.
And I do NOT recommend permanently running a microwave off an extension cord. That's very dangerous.
Sep 29, 2011 | Westinghouse WST3501 Microwave Oven
I've repaired my (R1460A, over the range, black) mwave several times, after having new cabinets and ceramic tile installed. I want to purchase a new one that will fit the existing wall mount and...
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Ask them about a "drop-in" replacement.
May 26, 2011 | Sharp R-1460 Microwave Oven
The display is dim on the oven. Everything works
1. Sometimes you can clean it inside to brighten it up for a while.
2. In some cases, we can replace the VFD to brighten one up if it's available for a given model.
3. The last solution is to replace the control circuit board.
For more specifics on the options 2 & 3, we would need your brand and full model number.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well as your symptoms, "dim display".
As for suggestion # 1, cleaning:
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Dec 13, 2009 | Jenn-Air JMC7000 Microwave Oven
How to set clock
Try these combinations:
Clock > 1 > 2 > 3 > Clock
Clock > 1 > 2 > 3 > Start
Clear > Clock > 1 > 2 > 3 > Clock
Clear > Clock > 1 > 2 > 3 > Start
If that doesn't work, contact the dealer you got it from and ask them for contact information for Brandt.
Oct 09, 2009 | Brandt S2600WF1 / S2600BF1 / S2600TF1 1550...
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
Cannot remove plastic upper exhaust fan grill for cleaning
Here are the steps to take:
1. Unplug it from the outlet.
2. Remove the two screws hidden in the slats of the grille.
3. Jiggle it up and out to remove the grille.
You can download your owner's manual here.
Dec 02, 2008 | GE JVM1850 1000 Watts Microwave Oven
What is the time for a 8oz cup of beverage to heat?
Depends on the power of the oven and to what temperature you are trying to heat it.
My rule of thumb is that a cup of water should boil in 1-1/2 to 2-1/2 minutes for microwaves rated at 1200 watts and 700 watts respectively.
Does this answer it?
Aug 26, 2008 | GE Microwave Ovens
Partial Power Outage
This could be very dangerous.
I would first call your electric company and ask if they have any problems with their lines, etc. We recently had this problem at our home and it was in their circuits.
My mother in law had a similar problem and we caught it in time. In her house, several outlets showed extremely low voltage and the others showed extremely high voltage.
It turned out to be a bad neutral connection on the line going from the pole to the house. The electric company fixed it at no charge.
Also, you or someone you know should measure the voltages coming out of your outlets, or call an electrician right away.
You may have a loose circuit breaker or a bad connection somewhere your electrical panel or elsewhere in your neutral line.
This can lead to destruction of your appliances or even a fire, so please don't delay.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 16, 2008 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
128 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
