Netgear router and Vontage phone box
Trying to set up netgear router with a cable connection and a Vontage phone service attached
  • 3 Answers
Check the MTU on your netgear and what the setting is on your 2wire gateway
default on netgear is 1500 (on netgear - advanced - wan setup)
if you are using PPPoE it probably needs to be 1492 (on 2wire gateway - broadband link - details )
Posted on Aug 12, 2008
Make sure the MTU is set the same on your router (netgear) as on your 2wire. default on netgear is 1500 if your dsl uses PPoE it probably needs to be 1492
  • 556 Answers
Have you reviewed the following page and links from it yet. They may answer your questions.
Posted on Dec 22, 2007
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
Can i set up a netgear wireless router if I have netgear prosecure box
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-
May 16, 2012 | Computers & Internet
I need the security key to my existing wireless netgear router.
The Security Key is normally used for Wireless routers to protect your connection from any unauthorized use. As you have said that you do not have the Security key for your router with you, the best way to connect your ACER laptop to the Netgear router is by asking your Wireless service provider to reset the security key & freshly reentering the same on both of your HP & ACER laptops.
Feb 06, 2010 | NetGear RP614 Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
Wireless won't work - can't type in registration boxes on netgear
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WGR614 Wireless Router
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Netgear Wireless Router Problems
Use the process of elmination, disconnect Vontage, does the problem go away? If no then look at the modem (cable or dsl).
Hint! If you have a cable modem, make sure all cable connections are tight from the outside of the house, to every TV, and from the wall to the cable modem. Use plyers to tighten all of them.
Jan 21, 2009 | NetGear WGT624 Wireless Router
Computers & Internet Logo
405 people viewed this question
David Payne
David Payne
