Question about HP DeskJet F380 All-In-One Printer
How to refill my unlimited ink.give step by step
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Step by step videos
 for black
http://www.youtube.com/watch?v=dhDaKSzou50
for color
http://www.youtube.com/watch?v=II9gpIXs_lE
Posted on Apr 26, 2010
How do i refill my hp cartriges in my hp 8610 printer step by step.
All refill sets, come with a good description. But before you buy ink, make sure your cartridges can be filled and the chip can be reset. So you won't end with filled and unusable cartridges and dirty hands.
Look here to see how things go:
Ink Refill Kit For HP Officejet Pro 8610 8620 8630 8625 8615
Mar 29, 2015 | HP Officejet Pro 8610 Wireless All-in-One...
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
Both ink refilled and after installing refilled ink priter giving incomparble ink massage abd nor working
I would remove the plug and hit the power button for 5 secs. Open and close all doors etc.. Make sure you see no paper stuck in the rollers.
Apr 16, 2011 | HP DeskJet F4280 All In One Printer InkJet
How do i go about refilling epson T5591/2/3/4/5/6
Before you can have unlimited refilling you must need this devices:
Option 1: The chip resetter which you will need to manually reset the cartridge before refilling to enable the printer to recognize a new cartridge.
Heres the link where you can buy the resetter:
http://cgi.ebay.ph/CHIP-RESETTER-For-EPSON-T5591-T077120-T078120-T0791-INK_W0QQitemZ290276640766QQcmdZViewItemQQptZBI_Toner?hash=item4395d607fe
Option 2: You a new set of empty cartridges with autoreset chips in it. No manual resetting needed, what you need is to refill and monitor the ink level.
Explanation: When the printer detected that the cartridge is empty, the printer sends data to the cartridges and the cartridge understand what the printer says, then the cartridge automatic chip resetter will re trigger the logic circuit built in into it to reset into full ink level.
Here is the link of the autoreset chip what Im taking about:
http://www.made-in-china.com/image/2f0j00wCVtjAmMPlchM/Refill-Cartridge-with-Auto-Reset-Chip-Canon-520-501-.jpg
Oct 21, 2009 | Office Equipment & Supplies
How do i make printer accept refilled cartridge t
Maybe you did not refill and insert it very well.
follow this steps in refilling your ink
1. remove the ink cartridge from the printer
2. make a hole at the top end of the cartridge, the hole can be made under the label on the cartridge by using a sharp/hot pin.
3. if you are using a syringe and needle in refilling, make sure you did not insert it into the hole too much so that the cartridge does not get damaged in the process.
4. make sure the ink is not over-filled to avoid spillage which can cause a hell of damage on you printer as it does to my previous one.
5. Gently use the label or a masking tape to cover the hole and insert it into your printer.
Note: The printer gives a message that the cartridge is empty or non compatible, ignore the message and continue with your printing.
It is also advisable that you refill your cartridge not more than 2 times.
If this solution does not help you, contact me on holamydes@gmail.com for more assistance.
Aug 15, 2009 | HP DeskJet F4280 All In One Printer InkJet
Canon MP610 ink refill
Without the resetter it will continue to give error codes, holding the resume button for 5-10 seconds sometimes will turn off ink level reporting, but you either need the resetter or to purchase and install reset circuit boards on each cartridge you refill.
Jun 18, 2009 | Canon MP610 Photo All-In-One Printer
How to remove ink cartridge for hp 4150 printer?
Hi there
step #0
Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
Step #12Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer. Step #23Press the change cartridge button. It is at the top of the printer next to the power button. Step #34Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process. Step#45#4Recycle the empty inkjet cartridge or have it refilled at an ink refilling center. Step #56Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed. Step #67Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door. thanks Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Help me replace the ink cartridge on my photosmart copier/printer
Step 1: Turn printer on -- open front door.
Step 2: Tilt cartridge down in front and remove cartridge.
Step 4: Refill cartridge with ink per instructions on refill kit.
Step 5: Reinstall cartridge by reverse of step 2, then 1.
Works for me -- I refill 6 or more times before replacing the
cartridge.
HP 1401 PSC
Aug 29, 2008 | HP Office Equipment & Supplies
How to refil ink for HP Deskjet D2360
refilling the cartridges is NOT recommended for your HP.
If you refill them and something happens, HP will void your warranty.
Go back to where you got the printer and tell them.
The cartridges that came with it should of lasted you a lot longer.
Nov 30, 2007 | HP Deskjet D2360 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
