Question about Dell E173FP 17" LCD Monitor
I just cant change the resolution of my desktop
  • 835 Answers
If you dont have many options at all on what you can do like change the resolution or change the color settings it could be possible that you dont have the correct driver for your video card.
Go to Driver.com
Use the free program that scans your computer and sees what drivers you need to update.
good luck.
Posted on Oct 05, 2009
I cant play my game on full screen,my screen resolution is 1366*768 and the game resolution 1024*680,my screen doesnt adapt...please give an idea
Just right click on your desktop and take properties and then choose display settings and then you will be able to change your desktop resolution as you require.
Good Luck
Feb 04, 2011 | Computers & Internet
Poor resolution. No driver software downloaded
you must install the graphics driver to get good resolution now the resolution will 600x800 if you dont have the driver you can download it from the net in the desktop right click properties settings and change the slider to get more resolution if you cant change the slide bar or the slide bar is grayed means the driver is not installed install the driver and try again
Dec 15, 2010 | Computers & Internet
My computer monitor is not displaying the icons well that is you cant read them well.
If you are getting problem in display then try changing the resolution of your desktop.
1. First right click anywhere on desk top and click on "Properties"
There you will find a tab named "Setting" Click on that.
There you will see "Screen resolution" and you can adjust the resolution .
Try changing it until you are satisfied
Hope the above information will be helpful to you.
Thanks.
Oct 07, 2010 | Computers & Internet
Everything on my desktop and internet so tiny i cant read.all icons and writting extremely small.
clik start then control panel then classic view then display and then select from drop down menu ...set it to 1024 x 768 resolution this should help
Aug 10, 2010 | E-Machines eMachines Desktop PC
I changed resolution settings by mistake.now to change them back i cant see bottom to click apply,also same problem when i try a restoe point
OK, when you first boot up, press F8 and select VGA MODE 800x600. Then when you get to the desktop, which you now will be able to see, go to your Video card resolution settings choose for now say, 800x600,and reboot,next time at the desktop, you can change resolution more carefully this time, :) Also, make sure you check the box, to apply, the resolution settings, without restarting the PC
May 21, 2010 | Microsoft Windows Vista Home Premium with...
I HAVE THE TV AS A COMPUTER MONITOR AND THE RESOLUTION IS WRONG. IF I TRY TO MAKE THE RESOLUTION DIFFERENT THE SCREEN TURNS BLUE AND I CANT SEE ANYTHING THE RESOLUTION ID 800 X 600 AND I CANT ACCESS SOME...
If you are trying to change your Graphic Card resolution try this.Right Cilck anywhere on your desktop screen,You should get a Display Menu Box.Click on properties and then settings.You can now slide the resolution bar to 1024 x 786 click apply then OK your resolution will change and ask if you want to keep this setting if you got a display click yes.Remember to make sure your TV supports this resolution.Good Luck.
Sep 11, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Frequency out of range, it read , please change the display mode to 1440 + 900 with 60Hz.
You need to Set the Desktop Display Settings to match those advised by the monitor... in other words, your desktop's resolution settings aren't supported by that monitor, so right click on desktop, choose settings, and change the resolution (1440 x 900 ) and set the Refresh Rate (60 Hz).
Apr 20, 2009 | Envision 19" Widescreen Flat Panel LCD...
Resolution problems
open your cpu remove the battery on the motherboard restart the pc without battery and refresh the bios by the jumper or a switch present near to the battery.
Change the resolution right click over your desktop blank area click properties and under setting you can adjust screen resolution
Aug 11, 2008 | Dell OptiPlex GX260 PC Desktop
Windows Xp
You need to install your computers drivers.
You noted that you have a dimension 3000.
You need videocard drivers to change resolution and networkcard drivers to connect to internet.
Il look for the drivers you need a post them in a minute If i find them.
Mar 17, 2008 | Dell Dimension 3000 PC Desktop
Cant change screen resolution
Need More info like model # of machine. Sounds like you have lost the correct video card drivers
Oct 31, 2007 | E-Machines eMachines Desktop PC
Dell E173FP 17" LCD Monitor Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
