Question about Square D Qob120 1pole 20amp 120v Circuit Breaker
We have a 15 amp double pole circut breaker that kicks each time it's set to on. We have replaced the breaker, but the sameproblem occurs. The protected circut is listed for a blower. The only blower we're aware of is in the heating system. We have several exhaust fans that work, and the heating fan also works on auto or fan only. Need guidance. Thanks Ken Rohm
  • Kenneth Rohm Oct 05, 2009
    The breaker box has been mapped. The home is new and the labels on the box should match the circut. The label says blower, and I'm familiar with only one blower-the one on the HVAC unit. Should I start there?
    The HVAC has two double pole breakers in the box and two on the unit. These are at least 40 amps. What in the heating system would power with 15 amps?
    Thanks
    Ken
    Thanks.
  • 770 Answers
You first must locate the circuit. If the breaker is kicking, something is not functioning after it kicks. The breaker is designed to kick when it is overloaded, pulling in excess of 15 amps. A grounding problem will cause the breaker to kick as well. You cannot, however troublshoot the circuit until you are aware of what appliance it is powering up. Once you discover what is being fed by the circuit, the wiring needs to be checked for continuity and proper voltage where it terminates at the appliance. If the wiring is good, and your breaker does not kick with the appliance disconnected, then you will have to troubleshoot the appliance to see what is causing the breaker to kick.
Posted on Oct 05, 2009
Cost for a 200 amp circut breaker
Any home supply store can give you the local cost. An additional cost will be even greater than just changing breakers. You must also change out the incoming service drop conductors. There may also be a need to have the power company's transformer supplying you home changed out. Check it out to be sure.
May 31, 2014 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
When I connected my oven to the electrical connection, the circut breaker keeps tripping. What can be wrong??
do you have a 50 amp double pole breaker for the stove ! it should be. if yes and it still blows, there may be a cord problem and it needs replaced.
Feb 09, 2012 | Thermador PRDS366US Dual Fuel (Electric...
There is the liquid seeping out of the breakers, it is not water the box is dry and it feels like an oil of some kind. breakers are working and are not hot. i have not seen this before. what is it and what...
It is oil. It's used to extinguish the arc.
When a circuit breaker trips, there is an Arc of electricity made inside the breaker, due to the contacts.
The contacts are instantly brought away from each other.
There are three methods employed to extinguish that arc.
[Extinguish the arc. Non-technical explanation. With out some medium to extinguish the arc produced inside, it would go Z-z-z-z-z-z-z-z-z-z-z-z-zap, instead of z-zap]
Oil, Air, and Sulfur Hexafluoride.
So yes, as long as the circuit breaker doesn't have to trip, and produce the arc inside, it is a working circuit breaker.
Is it a safe unit?
NO
The method employed to extinguish the arc if the breaker trips is leaking out.
Replace all breakers that are doing this.
Average cost for a GE single-pole 15, or 20 Amp is around $11 here. A few dollars more for 30 and 40 Amp, but usually double-pole breakers are used for 30, and 40 Amp.
Nov 18, 2010 | GE Circuit Breaker THQB BoltOn 1 Pole 15...
Bryant brd 30-30-30-30 quad replacement
You could get em here :
http://www.baybreakers.com/catalog/search.html
Why anyone would use a twin 2pole 30am breaker I'll never understand.
There is no way this size breaker could match up in quality to two full size 2-pole 30 amp breakers. If one wants to double up, do it with the 15-20 amp sizes.
Jul 16, 2010 | Bryant Westinghouse Bqc Quad Circuit...
Circut Breaker Trips
If the fault were with the product, the breaker would trip right away. You have either a poor electrical connection (power supply) or a weak or undersized circuit breaker. Free standing ranges usually use a 50 amp double pole breaker. Check electrical connections at breaker, range recepticle, and power cord to range to make sure all are tight. (obviously, have breaker off when making these checks)
Nov 23, 2009 | Refrigerators
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Looking for 2 15amp single pole pushmatic circuit breakers.
A Google search for "15 amp pushmatic" turned up several links. Here's one for a retailer with new ones and an eBay store with cheaper prices (maybe pullouts):
http://www.aplussupply.com/break/push/push.htm
http://stores.ebay.com/Sparkys-Place_Pushmatic-Categories_W0QQfsubZ10975954
Did you also check the big-box stores like Home Depot or Lowe's or electric suppliers in your area?
Feb 11, 2009 | Connecticut Electric & SWITCH UBIP130...
I need to strap two single pole breakers together to make 2 pole.
this is a double pole circuit breaker that is used for a 240 volt device the bar in the middle is to shut down at the same time you can take it to a hardware store to replace it but the bar is factory made siemens is one common breaker or there might be a substute they can give you also
Dec 01, 2008 | Siemens 2 single pole 15 amp breaker
Fridgeidaire clothes dryer
I will try this again i don't think i posted it properly.
On the power cord where it connectes to the dryer make sure the red and black wire goes to the outside screws (L1& L2) the white goes in the middle and the green goes to the dryer cabinet.
If you have the red or black going to the middle one it will trip the breaker.
Oct 06, 2008 | Whirlpool LER5636P Electric Dryer
Square D Qob120 1pole 20amp 120v Circuit Breaker Logo
50 people viewed this question
Top Square Electrical Supplies Experts
Steve
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Square Electrical Supply Expert? Answer questions, earn points and help others
