Question about Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer
I have Garmin GPSmap 498 and the wiring inside the case has broken due to the RF filter bouncing around. The power, both positive and negative and the depth finder wires have all broken off at the connector on the rear of the case and I can't tell which wire goes where since the broke off right at the solder points on the pins. All other wires are still attached. How can I find out which of these four wires (+,-, depth finder) goes where?
5 Suggested Answers
  • 18 Answers
SOURCE: Where do all the wiring go to on the garmin 400c
The rest of the wires are for interfacing (letting the unit 'talk') with other devices such as radar or GPS. These wires/colors are pretty standard and defined by NEMA (National Electrical Manufacturers Association). You need wiring diagrams for the devices to hook them up. For fun, see where 'nema' takes you with Google.
Posted on Jun 18, 2009
budgie140
  • 501 Answers
SOURCE: Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Posted on Jul 08, 2010
  • 5 Answers
SOURCE: I have a GPS Map 498-depth sounder not working? Ha...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
Posted on Jul 31, 2010
rickbrashear
  • 176 Answers
SOURCE: Connections problem
Question: What are the extra wires used for on the power cable for my fishfinder?
I found this on the carmin website under questions and answers. I think your cable is ok to use according to this.
--> Answer: Not all of the wires in the harness are required for use. To connect the unit to the power source, only the black & red wires are required (black to ground, red to positive). Here are descriptions of the other wires in the harness:
  • The Blue wire is used for a NMEA data out connection to another NMEA compatible device. The fish finder outputs NMEA 0183 version 3.01. The receiving device must be compatible with this format and looking for the NEMA sentences DPT, DBT, MTM, or VHW.
  • The Brown wire is used for a NMEA data in connection to receive data from another NMEA compatible device.
  • The Yellow wire is used to connect to an external buzzer or alarm to alert you to any alarms which have been set to sound on the device. The Yellow GARMIN wire connects to the negative end of the external alarm. The positive return on the alarm will connect to the red positive wire of GARMIN.
  • The green, white, and any other colors present have no connection purpose related to your fishfinder. The 18 Pin connector wiring harness is used by several other devices which utilize these wires.
If the device is only being connected to power & do not require a NMEA interface, PC connection, or external alarm support, only the red & black wires are required.
Posted on Jul 05, 2012
How to disassemle garmin 4208
If you have the correct soldering equipment and have the replacement part, it shouldn't be too hard. You'll need a jewelers screw driver to get the small screws out. Use a guitar pick to pop open the case. Work it around the case until the back half separates. Clicking and popping sounds are normal. Take out the battery wires. Do NOT yank on the wires... gently grab the plug and wiggle it loose.Remove the screws holding the board to the case to expose the solder side and remove the broken power jack.
Jul 17, 2014 | Garmin GPSMAP 4208 GPS Receiver
Garmin gpsmap 498 backlight
Did I understand this right, you do know how to replace the backlight, but you cannot locate it inside the unit ? Try to look here: http://goo.gl/6hCS
Jan 02, 2013 | Computers & Internet
My Garman gps map 498 turns on but stays to dark to read or see.
It's probably the ccfl is burned out. The illuminator is a very interesting (and very thin) little contraption. Inside the illuminator is an L-shaped ccfl (cold cathode fluresent lamp.) They run at very high voltages. Eventually the ccfl burns out.
Go to www.ccflwarehouse.com. They can fix you up with a mail-in replacement for around $35.
You can read about my experience at www.catalina22experiment.com
Best,
Zig
Jul 09, 2012 | Garmin Gpsmap 498, External Antenna With...
My Garmin GPS 498 stopped locating sattelites. How can I fix it?
Power off the Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode. I hope this helps. Good luck
Mar 14, 2011 | Garmin GPSMAP 498
My positioner arrow shows a question mark blinking in top and doesn"tshow my position, I all ready change the anntena and the problem persist
the blinking indicates a satelite not finding you. push the done button for that location and the Garmin should reset itself. don't start the garmin inside any garage.
kdog
Dec 29, 2010 | Garmin Gpsmap 498, External Antenna With...
How can I download a manual for a Garmin Gps 498
Here's the link to download the manual for free. If this solves your problem, please come back and rate our solution.
https://buy.garmin.com/shop/shop.do?pID=370
Jul 31, 2009 | Garmin Gpsmap 498, External Antenna With...
Garmin 498 - trouble finding satellites
Push power/menu together or power/page together. the whoole unit will reset. you will lose all saved data but this may help
Nov 07, 2008 | Garmin GPSMAP 498
GPSMAP 180 power/data connector
Okay
guys: book says:
PIN 1 (red) 10-40 volts DC
PIN 2 (black) Ground
PIN 3 (blue) NMEA out Shows this goes to Autopilot/NMEA devise and to RXD positive RXD negative goes to ground (black)
PIN 4 (brown) NMEA in Goes to GBR 21 Beacon Receiver to a blue wire, brown wire on thaat devise goes to PIN 3 and the negative goes to ground
PIN 5 (white) no connection
PIN 6 (Green) no connection
PIN 7 (yellow) goes to alarm low Shows going to negative terminal on alarm relay and positive terminal goes to PIN 1 (red)
All Greek to me, have fun
Seadrive Joe
Feb 03, 2008 | Garmin GPSMAP 180 GPS Receiver
Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer Logo
112 people viewed this question
Top Garmin Boating Experts
Mohamed Ismail
Mohamed Ismail
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
