Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
How to remove handle from Hoover 5445-900 upright wind tunnel vacuum
The switch is bad on this vacuum. How do I get the handle off and replace the switch? Thanks mary..
    Problem Solver:
  • 19 Answers
Hoover.com doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
http://www.hoover.com/pdfs/manuals/U5467900.pdf
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Posted on Dec 22, 2007
My hoover wind tunnel just quit while vacuuming. It is dead??? Two years old used about every other week? Any suggestions?
Some Wind Tunnels by Hoover have a poor design in the switch on the handle. Sometimes the switch does not turn on all the way and will stop running. Other times you can't turn the unit off.
Feb 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
Can I get a replacement handle for a hoover wind tunnel upright? It snapped off
That part is available. Includes the handle, cord and "digital" switches. Here's the link:
http://www.vacuummedic.com/product.php?id=389
Good Luck!
Vac Dr.
Sep 29, 2012 | Hoover UH30010COM Bagged Vacuum
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
Hoover Supreme wind tunnel upright model. I have a bad on-off switch. How do I replace it?
Take the two screw off the handle and then remove the upper handle devise. This will expose the real on/off switch which is on the top of the unit. There is a plastic actuator that rubs up against the switch when slide the plastic switch on the handle. What happens is the plastic wears out and does not make good contact with the real switch.
A simple solution is to wrap duct tape around the plastic actuator to make it thicker, which then makes more contact with the real switch. Put the cover back on with the two screws on the back. Slide the plastic on/off switch an it will turn on and off again!
Nov 15, 2010 | Hoover U6630-900 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Hoover Wind Tunnel does not turn on
that is a pretty good lifespan for a hoover, but its probably the power switch that's bad. Hoover uses a very poor quality switch. It shouldn't cost to much to have it replaced
Jul 05, 2009 | Kenmore 33721 Upright Vacuum
Hoover Wind Tunnel 2 won't stay on
Possible that the switch is bad, part #40309033, take the handle off, then the tool compartment, then you can get to the switch, almost bet that one of the contacts is bad.
Feb 20, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Problem with vacuum suction in upright position
Move the lever on the front of the machine to "carpet". It won't agitate on floor
Apr 11, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
472 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
