Question about Cameras
Camera will not recognize 16 gb sd card - Cameras
    Brigadier General:
  • 3,006 Answers
You haven't said which Aiptek camera you have, but a 16GB card will be an SDHC model and not all devices are SDHC compliant. SDHC stands for Secure Digital High Capacity and is an evolution of the original SD standard to allow greater than 4GB capacity.
If this is the case with your camera then it's a basic hardware issue and cannot be fixed by updating the firmware.
However, I have found that most "standard" SD devices (includes non-HD mini and micro SD variants) cannot handle the maximum 4GB either but work fine with 2GB maximum: this problem CAN be fixed if the manufacturer has issued a suitable firmware update.
If this answer has been helpful then please return the favour by taking a moment to rate my answer. If it hasn't then please reply with the exact model of Aiptek camera which you have and I'll do my best to provide a model-specific answer for you.
Posted on Oct 08, 2009
My alcatel one touch fiery wont recognize my 4gb sd memory card so What can I do
Sad to say, you may have to buy another brand SD card, my camera can't recognize Kingston 8 GB card but but recognize Lexar 8 GB card. Good luck.
Apr 05, 2014 | Electronics - Others
Vivitar dvr 410v3
According to the manual this is al you get:
  • Digital Video Camera
    TV cable
    Strap
    Built-in USB connector
    Vivitar Experience Image Manager software Installation CD
    User`s Manual
So as with most camera a SD card is not included.
You can choose a SD card or a SDHC card up to 16 GB. The 16 GB could be the max, because in the days this camera came on the market there were no bigger cards. Perhaps a 32 GB SCHC will work too.
Please don't try to put in a SDXC card, because the camera will almost certain not recognise a SDXC card.
Nov 10, 2013 | Cameras
Duracell pro photo 16 gb sd card Beeps when
What make and model camera? Bear in mind that your 16GB card is actually an SDHC card, not an SD card. Some older cameras and card readers will only handle SD cards (2GB or smaller) and not the higher-capacity SDHC cards.
Sep 25, 2013 | Duracell Pro Photo 200X Secure Digital Hc...
I insert a 16 gb SD memory card in my NuVue 700 plus photo frame and it is not recognizing it I took the picture with cannon slr camera. What could be the problem?
The NuVue 700 works with SD cards. Your 16GB card is actually an SDHC card and won't work in devices not specifically designed to work with SDHC cards. You need to use SD cards, 2GB and smaller.
Sep 25, 2012 | Cameras
MY CAMERA IS SONY CYBERSHOT DSC-S3000.PUTTING IN A 16 GB SD CARD WILL BE COMPATIBLE OR NOT?
Yes it should be OK.
If you want to also shoot movies with this Sony camers then a fast SD memory card is recommended ie. Class 6 or higher.
Mar 27, 2012 | Sony Cameras
Doesn't recognize memory card. I had an Eye Fi wireless memory card installed and now it's totally blank and the camera doesn't recognize it. Tried a regular SD memory card, and the camera doesn't...
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 23, 2010 | Kodak EasyShare Z740 Digital Camera
I HAVE A DXG DIGITAL CAMERA. WHEN I HOOK UP THE CAMERA INTO THE VIDEO INPUT THE PICTURE IS ALL JUMPY & UNCLEAR
Here's my problem: I recently bought as in today a PNY Optima 16 GB SDHC Card for my DXG-566V camcorder. When I inserted the card into it's SD card slot (which I assure you I did correctly), and powered up the camcorder, the camcorder didn't recognize the SD card, as it was still running off of the camcorder memory! Now I know the camcorder is just fine becuase after that I inserted my PNY 8 GB SDHC Card and the camcorder recgonized the card.
Please help me out here!
Jan 12, 2010 | DXG Technology DXG-566V Camcorder
Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Oct 20, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Cameras Logo
325 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
