Question about Samsung NC10-14ROBL Notebook
Screen problem NC10, vertical 'strip' in middle of screen
I have an NC 10 which worked fine the first 7-8 months. Then all of a sudden a screen problem occurred. This concerns a problem with the middle one-third of the screen, vertically. It seems that in this middle section 1 in 10 pixels or so is displaying the previous screen. So if I start up I see a slightly darker strip in the middle, if I start an application I can see for instance a previous dialog box shining through.
The strangests thing is that the problem is mostly there, but not always, sometimes it flickers on and off, completely unrelated to what I am doing at that specific moment.
Any suggestions?
  • 408 Answers
Sounds like the display is bad and needs to be replaced.
Posted on Oct 10, 2009
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
My tv was working fine till the hole screen shirnked to one lil strip in the middle how can i fix this?
Your TV unit has become victem of vertical collapse, a name obviosly choosen due to the picture shrinking down to a horizontal strip due to the vertical IC becoming faulty. Replace the verticalIC and check the surrounding capacitors and you should be fine.
Otherwise take it to a repair shop and they will be able to repair for you. I hope this helps. Good luck.
Sep 17, 2010 | iLO Televison & Video
Crash and blue screen with error message
You would first need to make sure Windows does not restart automatically when a blue screen error appears. Then you can analyze the problem and fix the cause.
Have a look at BSDO error fixing.
Feb 22, 2009 | Samsung NC10-14GW Notebook
Panasonic PT-53wx53G 53' projection tv problem
was your tv hit hard,a non magnetically shielded speaker set on top or under it?
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Polaroid FLM 2632 HDTV
I hae replaced my polaroid FLM-2632 3 times it is a crappy tv same problem every time do not buy one
Dec 18, 2007 | Polaroid 3211TLXB 32 in. LCD Television
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Picture problems
If the line goes across the screen you have a loose solder joint on the vertical output IC. I've seen this happen many times in Zeniths and a lot of other sets. If the IC is not loose then there is a loose solder joint somewhere else in the vertical circuit. These IC's are 10 - 13 pin chips that operate the vertical deflection on your set. I feel like a drop of solder in the right place will fix it! Stargazer
Apr 10, 2007 | Zenith C27A24T 27" TV
Samsung NC10-14ROBL Notebook Logo
317 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
