Question about Ruud Matching Split Air Conditioner
Gmp075-3 furnace burners ingnite then shut down
I have a gmp075-3 when you go to turn the heat on the burners ingnite like there supposed to all three light up then after 10 15 sec they shut down it will do this over again and then the blower will come on anyway and it will blow without the burners on also during the summer i notice even with the thermostate switch off the blower would come on by it self off and on usally i would call a tech out but my wife was laid off so money is tight but i am diseal tech and im pretty electrical and mechanicaly incline if someone can point me in the right direction i will greatly apppreciate it. Its starting to get cold down here i memphis. also i heard there supposed to be a fault light on it and where would the location of the circuit board be thank you for your time
    President:
  • 1,304 Answers
Ok check yoour air flow sounds like its tripping out on high temp
the blower comes on too cool the eqipment
you may need to clean the coils on top of the bloower
Posted on Oct 05, 2009
I would try cleaning the flame sensor. I also have a ruud furnace and it has done the same thing. Take a piece of sandpaper and . clean the sensor. It does not recoginize the flame and shuts the gas off. This is why it will start and then shut off.
Posted on Oct 06, 2009
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Fi have a older furnace that operates like this. main burners will come on then the blower turns on and furnace continues to heat untill it shuts down on the high limit. there is no blockage on the cold...
Maybe there is a blockage in the air conditioning coil above the furnace? This happens when people have pets, or dont use filters. Single phase 120-240 volt motors won't run backwards if you reverse the wiring that's dc or three phase, you have to check the rotation of the wheel, the right rotation is usually marked on the blower case. Some motors will allow you to change the rotation but you have to check the wiring diagram. Also use new capacitors when they go bad the motor can run backward. God luck
Dec 20, 2011 | Honeywell L4064B2236 Fan/Limit Control...
My furnace comes on and heates the house for about
There is a limit switch that is likely opening. Be sure your filters are clean and all registers and grilles are open and not obstructed. If the problem continues, you may have a dirty indoor coil or undersized duct work. Some models have a window where you can observe the LED lights. If when the furnace shuts down you see any blinking, you need to count the flashes and we can figure out what the problem is from there.
May 13, 2010 | Ruud UBHC Air Conditioner
Make sure filters are clean . if they are stopped up the unit will over heat. Lets start there. Russ
Mar 22, 2010 | Ruud UBHC Air Conditioner
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
I have a GMP100 furnace and I replaced the control board because the blower fan wouldn't kick off now and then. It all works great but the main blower only stays on about 45 seconds after the burner turns...
Check the board for a set of dip switches. Check against the old board for switch positioning. These control fan on/off times. Ensure you turn power off before changing switch positions. If no dip switches,??
Dec 04, 2009 | Refrigerators
Gas furnace wont stay lit
sounds like the thermocouple that senses when the burner ignites is faulty. when the burner is first lit it looks for a signal from the thermocouple telling it that it has ignition. i have had some luck removing the part (furnace off) and sanding it clean. this is located in front of one of the burners..Good luck
Jan 15, 2009 | Central Dual Temperature Heat Gun Kit...
Ruud Matching Split Air Conditioner Logo
348 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
