Question about Dryers
The motor is running but no hot air - Dryers
  • 770 Answers
If the dryer has no hot air, your element is not functioning. It has either gone bad or is not getting power.
Posted on Oct 05, 2009
Why is my heat or air is not blowing and car is running hot
How hot is the engine running in degrees f? Does the radiator fan run?
With hvac turned on, check voltage and ground at the blower motor. If good voltage and ground, suspect the blower motor is faulty.
Jan 02, 2016 | 1992 Saturn SL
Johnson air ease furnace blower motor getting hot
Check for correct voltage ,also would check capacitor and motor rotation.
Dec 08, 2017 | Heating & Cooling
I have a craftsman air compressor, model 919.167620, that will start running and then after about a minute it starts running slower and slower till it stops. it doesn't seem like it runs long enough...
The nonreturn valve that lets the air into the tank is stuck or faulty and not letting the air through, so pressure is building up in the pipe and cylinder and stopping the motor. If you open the back of the valve and run the motor you will know if that is the problem. Stephen.
Sep 24, 2011 | Garden
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
Turn on car and no air is coming out of the vents hot or cold; can here the compressor coming on but not air recieved.
Sir: It sounds like the blower motor is not working. If all fuses are good for the HVAC (Heater Air Conditioning) system then it could be an inoporative blower motor or a blower motor module, you can ddo this by using hot wires to see if blower motors (one hot wire 12V) (and one negative) ground wire. If motor runs, the module may be bad provided all electrical connectors are tight
Aug 31, 2010 | 2004 Cadillac Deville
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
Why the air in air compressor get hot while it's running?and then compressor shuts off no matter what the air pressure is.please help.thank you.
Your motor is running hot. Air blow it to clean it. Some motors require to be oiled on a regular basis. Check to see if yours is one of them. It helps too to rid your tank of the acumulated water.
Oct 23, 2009 | Air Tools & Compressors
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
Cooling system/ focus 02
I have had to mess with my thermostat housing a lot because of the poor design of the thermostat housing that causes a leak... don't worry about it. keep the system sealed (caps on) and it will eventually purge itself... the coolant reservoir being at the highest point means that all air will work its way to it eventually. it will not harm your motor.
Feb 28, 2009 | 2002 Ford SVT Focus
Drum does not turn but there is hot air
Can you hear the motor running? if you hear the motor then you have a bad belt if no motor noise.. then you have other problems... let me know?
Aug 26, 2007 | Maytag HYE3658AY Electric Dryer
Dryers Logo
Top Dryers Experts
