Question about Sony KP-43T70 43" Rear Projection Television
"convergence chip failure"
My problem is exactly what you explained as a "convergence chip failure" BUT trying to adjust the convergence I could not figure out. On my original remote there is no "tv settings" button, there is a menu button BUT there isnothing about "convergence settings" The TV is from 1999 and has gotten good use, it is our Back-up tv and it isn't fuctionable enough to watch, although I haven't tried it with 3-D glasses yet!! :) IF you could help me find the convergence section I would appreciate it so that I know if we need to replace the chips or not! Thanks in advance!! *(Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
  • Sony Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
Red gun appears to be smearing. Magic Focus doesn't help. Horizontal displacement of every other line to the right on the red channel. Tried other input sources to eliminate possible cable failure.
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
0667c5f.pngSolution
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jul 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Picture color ghosting
Your TV most likely has a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 20, 2009 | Toshiba 50HX70 50" Rear Projection...
Picture has 3d effect.
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 17, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 55 inch phillips tv that is showing a red line and also a double figure. the red line is along the outline of persons, numbers, etc. etc.
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 15, 2009 | Philips 55P8341 55" Rear Projection...
Picture curved in
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
May 22, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Cant figure out how to access convergence
Your TV most likely has failure in the convergence circuits. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Apr 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Feb 25, 2009 | Philips 60PP9363 60" Rear Projection...
KP-51WS510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Location of the convergence circuit board inside the KP46WT510
Screen looks 3D
>>>Solution<<<<
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red Convergence Bowing
Screen looks 3D
>>>Solution<<<<
Jan 02, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-43T70 43" Rear Projection Television Logo
432 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
