Question about Cell Phones
The outside of my phone completely dosent work. it tells me to press ok and it just dosent work..help! i tried takin it to my local verizon store. bt they couldnt fix it because im not serviced with them .how can i fix this problem myself. i also tried to take the batery out nuthin worksz.plese helppp!!
SOURCE: My phone won't send/receive calls
I had the same problem today - phone was working fine and then started with the cdma network not available. I turned the phone off, removed the battery, put it back in and turned the phone back on. It seems to be working OK now. This battery has had some issues anyway so I'm thinking it needs to be replaced.
Posted on Feb 23, 2009
Bajanguru
  • 7752 Answers
SOURCE: My phone won't send/receive calls or txts. NO SERVICE
what you need to tell the service provider is that to delete the vLR on they network then add it again
Posted on Jun 01, 2009
SOURCE: manuelly programming lg vx 9900 to cricket service
any missing info should be provided by your reseller.......
here is what I found...
Note: Some Programming must be done from the internal keypad / QWERTY Keyboard.
Alternate Programming Sequence for the VX9900 (Orange) or for newer software versions.
[#] [#] + [7][7][6][4][7][2][6][9][9][0][0] + [SEND]
OTA PROGRAMMING
Step 01:
Change ESN in billing system.
Step 02:
Power up the handset.
Step 03:
Dial *228 + SEND
Step 04:
Follow the VRU prompts
USE OTA Where Available. If OTA is not available follow instructions below.
Top
AKEY PROGRAMMING
Step 01:
Generate a random A-Key and power phone on.
Step 02:
With the flip CLOSED, press 2539 + * + * to access AKEY INPUT MODE.
Step 03:
Press 1 for Akey Entry
Step 04:
New AKEY displays, enter 26 digit A-key then press OK when complete.
PROGRAMMING COMPLETE
Posted on Jun 05, 2009
  • 36 Answers
SOURCE: I cannot turn off my LG chocolate
take it to verizon have them look at it they may be able to fix that if not they may replace it for you
Posted on Aug 01, 2009
shawntuggle
SOURCE: my chocolate only flashes to the verizon wireless screen
You need a new battery. The battery is either old or gotten Hot, Or has just been charged from Improper voltage. A new battery is needed. It cost around $50.00 although I wouldnt recommend getting a LG Chocolate since it seems to have bad reviews by other users who have had problems with it.
Posted on Aug 29, 2009
Why does my Samsung Gusto 3 cut on and off all day?
Problem: Samsung Gusto 3 Flip Phone turns off and on many times during same session
Return for Replacement Suggestion(s):
This is NOT a Samsung known issue because most units work fine. Therefore, it may be either:
(A) a hardware issue in which the phone needs to be taken back to your service provider whom you got it from to be replaced/serviced, OR
(B) it could be a software or battery issue in which you can fix yourself.
* If you don't feel comfortable trying to troubleshoot this problem yourself, OR if after trying to troubleshoot the problem you deem this a hardware issue (that you can not fix yourself):
Determine:
(A) What store you bought it from and their policy to return the phone. If you activated it, and have been using it for some time, returning it to the store may not be an option.. Call them to find out if they can help you with the issue
(B) What carrier phone service provides for this phone? If Verizon, take it to your local Verizon retail store (note: do not take it to a Verizon corporate store, they concentrate on sales and not customer service)
The store representative you bring the phone to will need to see this issue happening or you will have to replicate the problem in front of them, to prove that there is a problem and so that they can help you solve the issue or provide you with a replacement.
Things to bring:
Phone, charged battery, charging wall adapter, charging cable, original purchase receipt, original box with everything that came with it
A master reset is the last resort for troubleshooting. This reset erases all data and restore preferences to factory default specifications. Performing a master reset is only recommended when the existing data has been backed up or is unwanted.
From the main screen, press OK.
Select Settings then press OK.
Select Phone then press OK.
Select Security then press OK.
Enter the Code.
The default code is the last 4-digits of the mobile number.
Select Restore Phone then press OK.
Select Yes then press OK.
Press OK.
Enter the Code.
The default code is the last 4 digits of the mobile number.
User Manuals:
Gusto 1:
http://cache.vzw.com/multimedia/mim/sam_gusto/gusto.pdf
Gusto 2:
http://cache.vzw.com/multimedia/mim/sam_gusto2/gusto2_manual.pdf
Gusto 3
http://cache.vzw.com/multimedia/mim/samsung-gusto-3/basic-samsung-gusto-3-ug.pdf
Verizon Contacts Backup Assistant:
Gusto 1:
Initial Setup Backup Assistant Samsung Gusto
Gusto 2:
Back Up Contacts Backup Assistant Samsung Gusto Gusto 2
Gusto 3:
Initial Setup Backup Assistant Plus Samsung Gusto 3
How to Transfer pictures and other data files on Gusto phones to the computer
http://theinformr.com/answers/how-do-i-download-pics-from-my-samsung-gusto-3-to-my-computer
SOFT RESET Samsung Gusto 2
http://webcache.googleusercontent.com/search?q=cache:XsGogWARKtgJ:https://forums.radioshack.com/thread/6256+&cd=3&hl=en&ct=clnk&gl=us
HARD RESET Samsung Gusto 2
SAMSUNG U365 Gusto 2 how to hard reset my phone HardReset info
MASTER RESET Samsung Gusto 2 or 3
Master Reset Samsung Gusto 2 Gusto 3
Jan 11, 2016 | Samsung Gusto 3
Bluetooth Problem
Radios get old, the components age, and the radio needs to be re-tuned. It is probably working only at very close range, due to the reduced power from age. The BT radio was not designed to be tuned up. You may need to get a new phone to regain that functionality.
Try putting the BT device very close to the phone, see if that works.
Sep 06, 2017 | LG VX8350 Cellular Phone
Hi m having the same problem when i play ma music player it shows not enough memory...i hav already upgraded my software nd stored settings aswell bt its nt working....some ppl say it backup files cn solve...
Just follow the steps
Make a backup of contacts in your another sim.
Switch-off your phone.
1. Press and hold theree keys at a time;
Green dial key,
* Star key,
No. 3 key
Then Power on/off to swtich on the phone.
All switch will be pressed at a time.
.Soon an formatting text, will appear ,then stop pressing those switch, remember. 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
Hope this helps.
Jan 16, 2011 | Nokia 5130 Cellular Phone
I got the phone from a freind but they dont remember the code to the phone and its locked can u help
I suggest you go to your local Verizon Store or you can call Verizon Customer Service and ask how they can help you unlock your phone.
Jun 04, 2010 | Verizon Communications enV2 Cellular Phone
When I turn on my phone Verizon Wireless logo pops up and stays
Try taking it to a Verizon Wireless store for troubleshooting. This problem appears to be more than just the battery, as fully charging it did not help.
Jun 30, 2009 | LG VENUS Cellular Phone
I BROKE MY SCRREEN IN THE INSIDE BUT OUTSIDE PART IS OK!
Well, I have the chocolate as well. This happened to me when i fell with my phone in my hand. Well there is no immediate solution for the problem. Go to the nearest Verizon Wireless store, or call them up and they will ship you a new one. Hope I helped.
May 27, 2009 | LG CHOCOLATE VX8500 Cellular Phone
FSK Voicemail Indicator not working
When you press the voicemail button on your phone it is retrieving messages stored internally in your phone. Verizons Voicemail is a seperate entity where the message reside on the server. If you do not want to use the Verizon Voicemail, simply call the business office and ask them to remove voicemail completely from the account. That way your phones internal answerming machine whille then catch all the voicemails and you can go back to using your voicemail button to listen to them. Hope that helps you and everyone else out.
Tony T.
Jan 01, 2009 | Motorola Mobility C70 MD7081 5.8 GHz...
Unlock
If your service provider is Verizon Wireless, then dial *228 and press send. This will start activation, so when you hear the woman's voice (it's an automated message) choose option 1. The call will run for about 1-2 minutes. When it's finished the phone will beep and tell you programming is complete, so just press OK which reboots the phone.
This process, which only works on LG phones, resets the lock code to the last four digits of your phone number.
Oct 02, 2008 | LG CHOCOLATE VX8500 Cellular Phone
New bluetooth earpiece, no instructions
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done.
Jan 05, 2008 | OEM Systems Bluetooth Headsets - Model...
Bluetooth headset
you need to turn on the headset and to order the phone to search for BT devices.
May 19, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
