Question about Fuji FinePix S9100 Digital Camera
How to change the lens? - Fuji FinePix S9100 Digital Camera
How tout change Lens
Generally the COOLPIX line of cameras does not have a lens that can be removed or changed. Does this answer your question?
Some of these cameras have a lens cover that is like an external shutter. To use these cameras you must expose the lens, usually by moving a small sliding piece that is next to the lens, either up or sideways.
Oct 26, 2015 | Nikon COOLPIX Cameras
How do you change headlight lens 2007Toyota Rav4
U really can't change the lens..if u manage to it most likely won't seal properly..u can change whole assembly or buff out the fog on the lens if that's us issue
Sep 03, 2014 | Cars & Trucks
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
In camera optics, where is the aperture located? At the focal point? If so, why doesn't the aperature size ( f/stop) change the image sise on the film/sensor?
The aperture is located somewhere within the body of the lens, but not at the focal point of the lens. Lenses are designed so that changing the aperture changes the amount of light passing through the lens without affecting the image size. Some lenses are designed so that other changes within the lens affect the image size---that's what zoom lenses do.
Jan 12, 2011 | Cameras
Change camera lens
Hello there! I need to see the lens you bought or to let me know the type or brand so i can tell if this to replace the original one. You can clean the lens with the VFK1901 cleaning liguid and VFK1902 special cloth,you can order them from Panasonic dealer near you.
Jan 17, 2010 | Panasonic AG-DVX100 Mini DV Digital...
Changing lens on oakley razor blades glasses
Firstly, remove your nosepiece. Grab hold of the frame at one of the top corners with an index finger and thumb - use your other index finger and thumb to hold the lens, apply presure and gently pull apart. The notch will release. To mount your new lens, insert one notch into the frame and press the other notch into place. Do not apply pressure to the stems or hinge.
Sep 04, 2009 | Oakley Crush OAK0333 Wrist Watch
I need to know how to get the tail light lens cover off to change signal bulb
Open hatch and on inside of body where the lens is are two horizontal screws going into the lens, remove them and pull the lens towards the back of the vehicle carefully. Good luck
Apr 27, 2009 | 2006 Dodge Caravan
Lens won't allow me to change aperture & several other functions on camera
The USM engine may be out of order, or there is a bad contact in the lens.
Oct 11, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon 30D
Is the lens a Canon EF or EF-S lens? Have you used it before on this particular camera body? Did you do anything else (change memory cards, etc.) at the same time you changed the lens?
Try taking off the lens and cleaning the electrical (metal) contacts on both the lens and the body with a small dust-free cloth or pencil eraser. If that doesn't help, switch in the lens you were using before. If it works with the original lens, there may be an electrical problem with the other one. If it no longer works with the original lens, you may need to have it serviced.
Feb 08, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Error
there are two possible problem of your camera...change first the lens or try other lens if you have,normally the lens have an error is on wide position...if nothing happen when you change the lens the possible problem is the shutter of the camera.......
Aug 24, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Fuji FinePix S9100 Digital Camera Logo
15 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
