Question about Microsoft Computers & Internet
Tcp error on connection in internet - Microsoft Computers & Internet
    Sergeant:
  • 191 Answers
Tcp error means there is something wrong with TCP/IP PROTOCOL, with is basic network service. try restarting services. if it won't work there may be something wrong with DNS server
Posted on Oct 05, 2009
TCP Err 10050042
I have no idea about cash registers but a TCP error sounds me to Internet connection. Chack if this might be the reason
Jun 26, 2015 | Retail Supplies
Tip
Network sharing issue
In Multiwindow platform normal,sharing folder and printer is always big issue.
Error type:
ex:
\\server is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.
This method can be used for many network error
Solution:
1)Fixing the winsock and tcp/ip .
On the run command :
for winsock run:
netsh winsock reset
to reset tcp/ip run:
netsh int ip reset c:\resetlog.txt
or
run winsock fix from www.snapfiles.com/get/winsockxpfix.html
2) Enable NetBIOS over TCP/IP
open up Network Connections, under Control Panel.
Right click on your network adapter and click on Properties.
Click on Internet Protocol (TCP/IP), then click on Properties.
Click on Advanced, and click on the WINS tab.
Even if it is set to Default, set the radio button to Enable NetBIOS over TCP/IP.
Press OK on each screen until everything’s closed.
Go back to the client machine and try again.
You should be able to connect!
3)dnsflush
Open Network Connection
Check box File & Printer sharing > ok
Disabled NIC
Enabled it back
Open CMD > ipconfig /flushdns
ipconfig/registerdns
4) Make sure windows firewall and antivirus firewall turn off
on Apr 21, 2010 | Computers & Internet
Tip
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 | Computers & Internet
Tcp error 10050042
TCP error means you are not connecting to internet, reset your modem and try again make sure you can get to yahoo.com or similar site, if you can then press star key above red x go to tools and then ping test.
then toruble shot and then repair key
Jul 14, 2014 | VeriFone Retail Supplies
Error code tcp on internet connection for sharp tv
Yes, my firewall was blocking it. I got around it and it fixed the problem.
for more help visit CBR Tech Solutions
Apr 21, 2012 | Sharp LC-70LE640
I keep getting kicked off during online play (8002AD23). I have a wired, ethernet connection
That error means your PS3 is having trouble connecting to the PS Network. That can be caused either by your internet speed (if you are downloading something for example, it may lower your speed and cause this error) or by a random glitch on the PSN. You should also try forwarding the ports from your router. The PS3 required ports are : TCP 80 TCP 443 TCP 5223 UDP 3478 UDP 3479 UDP 3658
Also keep in mind that it is recommended you set your PS3 to use a Static IP. I hope that helps
Philip
May 27, 2011 | Sony Playstation 3 (PS3) Console
Error code for sony 3 807
"Hey, here is a list and a reason of some of the error codes you may encounter whilst connecting your PS3 online, also the required ports need to be opened in order to play online.
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation 3 Error Code List
0710102 - DNS Error; No DSN server available.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
80010510 - Will not play hard drive games - Cause unknown
8002b241 - DVI has no audio.
80028EA5 - Unknown
80029023 - Exchanging Key Information exchange has timed out
80029024 - The attempt to obtain an IP address has timed out
80029564 - Downloaded Game will not install - Cause unknown
8002F997 - Can not update XMB firmware
8003051E - Game will not Save
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Press the x button to repair and restore default"
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
80710092 - "An error has occured. you've been signed out from the ps network" - (connection dropped?)
80710102 - PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out.
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond"
http://community.us.playstation.com/thread/2996553?start=0&tstart=0
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
Have speedstream model 4100 modem....4 green lights...activity light blinks some.....cannot get on internet....dns problem error message
- go to network connections
- right-click Local Area Network and select Properties
- click to highlight TCP/IPv4(vista) TCP/IP (xp)
- click properties
- change DNS servers to 8.8.8.8 and 8.8.4.4
Jun 01, 2010 | Dell Inspiron 2500 Notebook
Problem in proxy settings
Log Out...Could not Connect...
Dear User, If you are behind a firewall or within a company local area network (LAN), you will need to open outgoing TCP connections to Port 51215 on your proxy server.
Oct 27, 2008 | Computers & Internet
Siemens Gigaset SE587 WLAN dsl
Error #105 TCP connection to the server timed out.
IMPORTANT NOTE: If you have received this error, you are not using the latest RealPlayer. RealPlayer 8 Basic is a FREE, recommended update available for Windows 95/98/NT and recent Macintosh systems.
If your system meets the minimum system requirements, it is recommend that you update your player.
The attempt to connect to the TCP server took longer than allowed. This problem may be caused by a high network load (i.e. too many people on the internet) or the server maybe down.
If the load is too high, you may try later or you can increase how long your computer waits by changing the Network timeout values under the Connection tab in the RealPlayer Preferences. If the server is down, the only solutions are to try a different server or contact the server administrator for the site you are trying to access.
Mar 18, 2008 | SMC EZ Connect Wireless Networking Starter...
Computers & Internet Logo
126 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
