Question about ASUS PU-DLS Server (PU-DLS/LAN/PA/SC) Motherboard
Upgrade from SB 1.1 to USB 2.0
I ahve a PC based on Asus PU-DLS. It is very fast and runs smoothly. I wonder if it will be possible to upgrade the USB 1.1 port to USB 2.0.
    Sergeant:
    Novelist:
  • 191 Answers
You'll have to add an expansion card. The motherboard indicated has PCI expansion slots. You can install a 4-port USB 2.0 expansion card. You can find them at local electronics retailers including Wal-Mart and Radioshack. Or, you can get online at places like www.newegg.com.
Bret
1-2-1ComputerServices
Posted on Oct 05, 2009
Where can I get a technical manual for an ASUS laptop K50IJ (2010)
Every thing on a laptop is chip centered, you cannot upgrade hardware.
Jan 15, 2013 | ASUS Computers & Internet
Trying to use USB connection. Power good. Program install seems correct. When told to connect USB to computer, nothing happens (no recognition.) Have to cancel out of install. Have checked out supplied...
Following are three possible issues you can easily investigate and correct:
Upgrading DLS or Adding an Additional LabelWriter
A previous LabelWriter printer may still be installed with documents in the print queue. You must delete any documents in the print queue for all previously installed LabelWriter printers before proceeding with the installation.
1.Open the Printers folder. Based on Operating System and system configuration, the Printers folder can be accessed in one of the following ways:
Start > Settings > Printers
Start > Control Panel > Printers & Other Hardware > View installed printers or fax printers
Start > Control Panel > Printers & Faxes
2.Double-click on the LabelWriter printer, the print queue will open.
3.Delete any pending print jobs and close the print queue.
4.Reboot your computer and re-run the DLS installation.
Installing DLS and a LabelWriter for the First Time
Some antivirus or anti-spyware applications may prevent the installation of DLS and the LabelWriter printer. You may have to temporarily disable these applications in order to successfully complete the installation.
1.Restart your computer.
2.After restarting, temporarily disable any antivirus and anti-spyware applications.
3.Install DLS, connect the LabelWriter when prompted during the installation.
4.Once installation has completed, re-enable any antivirus or anti-spyware applications.
DYMO Label Software Fails to Install because Word or Outlook is Running
While installing the DYMO Label Software (DLS), prompted with a message that Word or Outlook is open. How can I resolve this?
1.Exit Word and Outlook.
2.Open Task Manager.
??¦To open Task Manager press Ctrl - Alt - Delete.
3.Click on the Processes tab in Task Manager.
4.Verify that WINWORD.EXE and OUTLOOK.EXE are not running processes. If present, select every instance of WINWORD.EXE and OUTLOOK.EXE and click on End Process.
5.Close Task Manager and reinstall DLS.
Should you require updated driver/software for your printer and operating sytem, check here.
Trust this helps resolve your installation problems. Please vote.
Dec 29, 2010 | Dymo LabelWriter 330 Thermal Printer
I have an old desktop pc, ASUS P4S533MX, Intel socket 478, with SiS PCI IDE Controller.. ( IDE ATA/ATAPI ) 1. Can I upgrade the Radeon 9250, 128 Mb DDR 64-bit to something better? 2. Is it...
well...ASUS P4S533MX- Intel socket 478 allow maximum processor upgrade from 3.2 GHz upto to 4.2 GHz.
for upgrade the Radeon 9250, 128 Mb DDR 64-bit ....whole moherboard along with new processor has to be replaced. an expensive deal..
better to buy new motherboard+compatible processor of ur choicce
Sep 19, 2010 | Intel ASUS P4SC Socket 478 Pentium 4...
Amd processor upgrade
The M3N78-em mobo doesn't support AM3 processors. It is an AM2 / AM2+ platform. A wonderful GPU for you would be this. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102858
If you have any other questions please write back in this thread. I will be happy to help you through your computer upgrade.
Jul 06, 2010 | ASUS M4A78T-E Motherboard with AMD Phenom...
Prossor help
MS FlightSim is really tuff on the processor. You are better get a Quad Core Intel Processor, as no upgrade is possible for your Laptop. Also get a good graphic adapter, something like ATI Radeon 4850.
Mar 27, 2009 | Acer Aspire 5520-5156 Laptop
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
I own the asus 901
I assume that you are referring to the maximum memory of this computer. It is only 1 gigabyte, not upgradeable to 2.
Nov 29, 2008 | ASUS Eee 4G Notebook
Fault caised by bad contact and raw disk - unformatted can't found FAT system
It appears there's a dault with the data/memory card.
You will need to upgrade the XMenu:
How to upgrade the XMenu:
>>>> Warning! All data on the MK5 will lose after you start the upgrade! Please backup it first!! <<<<
1. Use MK5 USB Linker connect PC , and enter USB data exchange mode , PC will detect one removable disk (MK5) have inserted
2. Copy "MK5_Menu_V1.39_AUTO_Upgrade.nds" to MK5
3. Restart NDS, enter MK5 menu, choose "MK5_Menu_V1.39_AUTO_Upgrade.nds" and run it,and restart NDS.
4. When NDS power on, hold L+R+A+B+DOWN to fast format whole MK5, or you can use A+B+START+SELECT+UP to make a low-level format ,then copy all data (include folder) from this uncompressed file.
5. Now new system is ready ,restart NDS and enjoy it!
May 12, 2008 | Nintendo DS Lite Console
Cpu upgrade
smithy569, your board in your HP is a ASUS P4S333-M
Here is the CPU support page from ASUS for your board.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P4S333-M
Please let me know how you make out.
Thanks
Dec 18, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
ASUS PU-DLS Server (PU-DLS/LAN/PA/SC) Motherboard Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
