Question about GE Washing Machines
Our washing machine is draining immediately upon start
Our washing machine is draining immediately and won't fill up when the machine is started. The water continues to run and never moves to the wash stage.
  • 3,230 Answers
HI there,
Check the followings -
1.  Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
2. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
3. Inlet spout -check for a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Good Luck!!
Thanks
Posted on Oct 05, 2009
Water drain out immediately while filling the washing machine
you should check 2 things the drain pipe should be higher than the drum or there is some dirt in the thin pipe of the pressure switch try to blow air in it in order to clean it
Feb 10, 2014 | Simpson Esprit 750 Top Load 7.5kg
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Washer will fill and drain but won't wash and rinse
Check for a modular unit in the machine that controls the wash action of the machine. If it has malfuctioned there will be no power for the motor. Check with the spares departtment if your machine has this unit
Mar 02, 2013 | Haier HLP21E Top Load Washer
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
My kenmore 80 series will not fill to wash - it starts to fill with water and then starts draining immediately??
If the washer drains immediately as it attempts to fill,or if it has problems with maintaining the water level after it does fill, this can commonly be caused by what is known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Read through the link provided and let me know if you have any questions. This could be a simple matter of drain hose placement. If this does not correct your problem, please let me know. I hope this helps you.
Oct 12, 2009 | Washing Machines
Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Jul 30, 2009 | Washing Machines
Series 70 washing machine Will not fill with water
Sounds like your pressure switch behind the control panel is stuck. Try unhooking the tube going to the switch and see if it breaks free. If not replace the switch.
Nov 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine problem
make sure the drain hose is higher than the height of the water. if the hose is lower it will just keep draining out
Sep 21, 2007 | Washing Machines
Washer fills and drains repeatedly
Have a look at the routing of your drain hose. It sounds a bit as if: a. The highest point of the hose isn't high enough (you normally want to aim for about 3 feet off the ground) - so that water starts draining from the machine before it is finished filling. and b. There isn't an effective air break or anti-siphon valve where the drain hose goes into the domestic drainage system - so that once the machine starts to drain by itself, it continues until empty. A.
Jun 07, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
21 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
