Question about Sony Cybershot S650 Digital Camera
Flash When I take pictures, all of the faces are completely whited out. It's like the flash is too bright but when I adjust the flash, then it's too dark. I'm sort of confused as to what to do. I would love to be able to use the flash without whiting out all the faces and bleaching out the background. I've tried adjusting the brightness and the flash but that doesn't work. Is there anything else I'm doing wrong?
  • 45 Answers
I rally dont know, i personally always keep my flash on auto and keep the brightness auto or 50%. if this is the case, then i strongly recommend contacting Sony and asking them for a solution, or taking it down to the store you purchased it from and asking them to fix it or refund it!!!
hope this helps and sorry i couldn't help in much detail!!
keep in touch and tell us how its going
Posted on Dec 22, 2007
Dark picture..not bright picture
The whole point of a webcam is to be able to see the person you are speaking with, and let them see you. When the image broadcasted by your camera is too dark, the person on the viewing end won't see anything but shadows and dark shapes. Learn how to brighten your webcam image so the people you chat with can see you.
Place lamps behind and to the side of the webcam. This casts a light on your face, but the lamps will not wash out the image because they are behind the camera. Turn off lamps that are behind you. You have trouble seeing things when you are looking in the direction of the sun or a light bulb. Your webcam has the same problems. Don't make it stare at a bright light. Open up a white screen on your computer to brighten your face. The white screen will create the brightest possible light from you computer screen and help lighten your webcam image. This option is best when lamps are not available. Open up an empty tab in your Internet browser, or a blank Notepad document, and expand it to the full of your screen. Adjust your webcam settings. The settings available to you will depend on your webcam, but many of them offer a "Brightness" setting that you can increase to lighten your webcam. Open the program that came with your webcam, then look for a "Settings" or "Options" menu. Increase the "Brightness" setting until it has lightened your webcam enough.
b>
Feb 08, 2013 | Gear Head Computers & Internet
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
Sylvania tv srt2232s picture is dark. i have used the remote gone to pictureand still unable to adjust brightness. need your help to adjust brightness. What do i need to do to change the brightness
Hi
Remove back fron tv locate line flyback transformer
on this transformer there should be two adjustment controls very carfully adjust the bottom one, do not adjust to far as picture will have fine white lines on it
May 17, 2010 | Sylvania SRT2232S 32" TV
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Dark picture
@ 6 years old I'd be willing to bet that it's time to replace the lamp. They lose brightness over time so that could be what the problem is.
Dec 14, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Flash makes my pictures too bright/too dark
u might want to try and put a coffee filter over your flash when you take pictures to make the flash less bright. it sounds really silly but it actually works.
Oct 29, 2007 | Samsung Digimax S500 Digital Camera
My picture is too light (overexposed).
If you're using the forced flash setting, it may be too bright. Try setting the flash to Auto. If you're facing a bright light source, you may need to shoot your picture from a different angle. Use Image Expert to adjust the picture's brightness, as described on page 9-4. Set user mode to Manual and adjust the camera's exposure setting.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Sony Cybershot S650 Digital Camera Logo
71 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
