Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA Scenium D52W136D Issues
I have an RCA Scenium Model D52W136D that has multiple issues. I have standard cable and use the set's internal tuner. Within a few minutes of turn on, the screen suddenly blanks to snow. The fix is to either turn it off and back on (works everytime) or punch channel 48 on the remote and the tuner seems to reset itself and then works for all channels (this works sometimes). This problem occurs once or twice within about 5 minutes of startup then subsides. Also, the main menu will no longer allow the internal DVD option. It acts the same when using the front control panel controls so I dont think its the remote. What is up with this set? I am in the Bel Air, Maryland area - can I get anyone to service it?
  • 579 Answers
This definitely sounds like bad solder joints in the tuner or in the tuner connector. If you know what a tuner pack looks like you might be able to find it inside (no doubt right by the cable connector) and try resoldering it. Forget about resoldering inside the tuner, nobody does that.
Posted on Dec 31, 2007
    Sergeant:
    Champion:
  • 298 Answers
Links to Electronics Servicers in you area
sound like problem in active filter
section of tuner circuit PLL, etc
Posted on Dec 22, 2007
  • 265 Answers
Your set requires a qualified service technician to repair it. Sears repairs all major brands, regardless of where you purchased it. There are also many other repair facilities in your local area:
http://yellowpages.superpages.com/listings.jsp?C=tv+repair&L=Bel+Air+MD&MC=1&OO=1&F=1&CP=Computers+%26+Electronics%5EConsumer+Electronics%5ETelevisions%5EService+%26+Repair%5E
D52W136D
Common issue in this model---look to see if the option for convergence still appears in the menu---if not you have a bad part right at the flyback causing this---a kit of 3 parts is available (tvparts.com).
Set is also for this issue prone to bad solder connections at the flyback and right around it that will cause convergence issues.
Oct 29, 2012 | RCA D52W136D 52 in. TV/DVD Combo
No picture/sound
YOU HAVE AN INTERNAL TUNER FAILURE IT NEEDS TO BE REPLACED
CONTACT RCA FOR REPLACEMENT PARTS OR INFORMATION
here are some contact information for rca
http://www.rca.com/content/viewdetail/1,2811,EI45168,00.html
Questions about operating or setting up your
HDTV: Call us toll free at 1-866-SCENIUM
(1-866-723-6486), or send us an email.
Quality comments? Call us toll free at
1-866-SCENIUM.
Jan 06, 2008 | Televison & Video
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
WHERE IN THE SETTINGS DO I FIND THE INTERNAL SPEAKERS TO TURN THEM ON
If you can't find them in the sounds settings, then on the back the unit itself, there will be an actual switch(by the tuner)
Mar 10, 2010 | RCA Scenium D40W20 40" Rear Projection...
VIDEO 1 AND VIDEO 2 DON'T WORK WITH SATELLITE. VHF WORKS BUT NO SOUND
First of all check if theSatellite box or the RCA cable is working ok with other equipment/TV if they both r working fine then their is an internal problem with ur TV.Show it to a authorised service person.
Jun 01, 2009 | Televison & Video
RCA SCENIUM MODEL # D52W136DBYX1
If it's normal television, with CRT picture tube . then it's Blue gun which went off normally its a solid state circuit which can malfunction. which is located at the back neck of picture tube blue gun out put circuit a transistor or a resistance of 470 K or 390 K Ohms can blow off. or the tube base can loose contact with the blue gun pin.
Feb 06, 2018 | RCA D52W136D 52 in. TV/DVD Combo
Rca 14" truflat
This set was made before it was required to have digital tuning built in. You would need a digital converter box if you want off-the-air reception. (The federal program at www.dtv2009.gov that is giving $40 coupons toward purchasing a converter is out of money right now and is only putting people on a waiting list. It also looks like the changeover to digital is going to be delayed again, so you might not need to worry about it for a while longer.)
Feb 06, 2009 | RCA 27F534T TV
TV RCA SCENIUM D52W136D 52in
Problem solved, it was my green driver this time and only $25 to replace.
Jan 16, 2008 | RCA D52W136D 52 in. TV/DVD Combo
I have an rca scenium
turn off autoformat in customer setup
Feb 25, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Won't tune in all channels
Do you mean the channels from the internal tuner which would be channels 22 to 68, or do you mean satelite channels, as I do not know whether this set has a built in satelite receiver? Satelite broadcasters are often changing frequencies or satelites.- Programs come and go!
Oct 20, 2006 | RCA F27440 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
