Question about Garden
Dirty spark plug & oil.
I have a B&S 4-stroke lawnmower. The spark plug gets incredibly sooty after just 10 minutes or so of running the mower. I clean the plug, replace it and 10 minutes later (if that) the mower stops and the plug is dirty again. I strongly suspect I had too much oil in the mower so I replaced the oil with about 50% of what was in there before. After less than 30 minutes the new oil was also very black. Can you give me some tips to fix these problems.
This was a test message for a local consumer group (over 12,000 members) to see if you actually offer a realistic service or just exist to gouge money. Unfortunately the latter seems to be the case.
Posted on Oct 06, 2009
My 4 stroke petrol lawnmower engine won't start - where's the problem?
Hi try a new spark plug check if it's got petrol check for spark put the lead on the plug before U put it in hold the side of plug on the mower & pull the cord to c if it's got spark.. check for compression put your finger over plug hole & pull the cord if it's got compression it should push your finger away good luck
Nov 16, 2016 | Garden
I have recently been given a Victa Catch and Release Lawnmower,but no manual. How much oil do I put in before commencing use. And How do I drain dirty oil?
Victa catch and mulsh ?
search pops these up as 4 strokes
which model and a internet search gets you its user manual
start with 600 ml oil and top up as required
try not to over fill
look for drain plug up under blades or on the side of motor
Nov 06, 2016 | Garden
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
How to fix a 3.5 lawn mower?
HELLO,
You can fix these yourself, all you have to do is to follow the instructions below,
1 Remove the spark plug lead from the spark plug and move away from cylinder head. Always do this before attempting any repairs to a lawnmower.
2 If your lawnmower is a "four stroke" mower (separate gasoline and oil), tip the mower so that the spark plug is pointing skyward. Never tip it on its side with the spark plug to the ground.
3 If your lawnmower is "2 stroke" (oil and gasoline mixed) turn off fuel tap. You can tip a two stroke mower any way that is suitable to you.
4 To change a blade, or blade disc, it is often easier to remove the spark plug and feed a length of string into the cylinder head to 'lock' the piston while trying to un-do the blade bolt(s).
5 Check the motor's "air filter" while doing this sort of maintenance as a dirty or clogged air filter will affect engine performance and increase fuel consumption of your mower. Symptoms of a clogged air filter include inability to start, starting and quickly stopping after several sputters, or a weak idle. You may also see oily or smoky exhaust.
6 If your mower is a "four stroke" model, change the oil at least once a year. When it is tipped over with the spark plug in the air, is a good time to remove the "oil fill" plug and drain oil into an old ice-cream container for recycling.
I hope this will help to solve the problem.....
May 31, 2011 | Craftsman Garden
Spark plug fouls out after 5 minutes of running
If plug is sooty, this is due to mixture being too rich. This can be caused by dirty air filter,
Clean or replace the filter and if this doesn't improve the situation, adjust the carburettor to ensure the mixture isn't too rich.The procedure for this is to turn the adjustment screw (if there is one present) slowly anticlockwise until engine almost cuts out, then turn the screw clockwise until engine almost cuts out. Set the screw halfway between these two positions.
If the plug is black and oily this could be due to engine bore wear and oil getting up by the piston into the cylinder (in the case of a 4 stroke engine) or due to an excess of 2 stroke oil in gas (in the case of a 2 stroke engine) Gas / Oil mix should be in the ratio of 50:1
Nov 15, 2010 | Mk Diamond 159345 MK - CX - 3 H 6 - 1/2 HP...
Losing RPMS
Try a new spark plug. Carbon build up from the mower oil is probably robbing some of the spark. Mix the 2 stroke oil 32 to 1. That means 4 oz. oil per gallon of gas.
Dec 27, 2009 | 2004 Sym Husky 125
White smoke coming out of lawnmower my son was cleaning garage and thought he would save space so he tilted the lawnmower on its side my brother said that gas and oil may have mixed together and thats...
The oil is drained by removing the drain plug on the underside of the mower, where the blade is. The gas can be drained by removing the gas line from the carburetor and letting the gas drain into a container. Remove the spark plug wire from the spark plug before any work is done to the mower. But, really depending on just how long the mower was on its side, the mower should be OK after running for a few minutes. Have you let it run for several minutes? The oil in the combustion chamber should burn off. The one thing to check is the spark plug. It may have some carbon buildup on it from the oil. It can be cleaned with some spray carburetor cleaner, or you can just replace it for a few dollars.
Aug 12, 2009 | Garden
2 stroke gas mixture in 4 stroke lawnmower
Your carburetor jet is probably clogged with oil. Try an additive in the gasoline -- something for cleaning injectors -- it will only require a small amount -- use the same ratio as described on the label.
You'll have to keep starting the engine to get the cleaner into the carburetor. After you've done this several dozen times, let it sit for a day.
If this doesn't clean it out, you'll need to take the carburetor apart and clean it.
May 05, 2009 | Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
