Question about CDA CI392 Front Load Washer
Handle came off when i closed the door now my washing is stuck in the machine how can i open the door
    President:
  • 1,304 Answers
On the bottom you should see a lil door
pop that open with a flat head
pull the strap door open
Posted on Oct 05, 2009
the dr
  • 447 Answers
SOURCE: help needed indesit washing machine
well it would help to know brand/model#
Posted on Oct 03, 2007
Malcg
  • 32 Answers
SOURCE: WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on Apr 13, 2008
  • 566 Answers
SOURCE: cannot open door as handle broken for indesitw103
hiya easiest way to open is = first unplug power! then turn off water hoses to machine then draw machine out to gain access to pipe connections on rear and disconnect them ? now remove rear panel top screws as these also secure the top panel at rear then lift rear of top panel and pull to rear the panel now can be removed ? you now have access to the latch on front panel inside? if you reach down you can flick latch /hook clear to open door ? at this point after removing washing? you can observe the door inner remove inner panel that surrounds/secures glass? then you can observe how the door handle/lock assy is secured ? easy diy you can browse yellow pages for the replacement handle assy? machine repairs/spares reassembly is reverse to above wish you well this is a common occurance and should not have prob obtaining parts for the MAKE/MODEL NUMBER ? when enquiring for parts best wishes
Posted on Oct 21, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
Tip
Difficult to open washing machine doors
some makes of washing machine doors can be very tight to open resulting in the door handle taking the strain and premature failure....I find if you take a wet rag and rub both the door boot seal and washing machine glass where they both make contact this lessons the DRAG on the door, it will close easy and glide open making the resistance to the door handle kit lower increasing its life span...
on Apr 06, 2010 | Washing Machines
My door will not open on my washer and it will not start the wash
try pulling the handle with youre left hand kind of hard & at same time push in on door with right hand close to handle work it back & forth if that don't work try jerking on handle with left hand with right one on machine gasket maybe stuck or handle broke inside door hope u luck Nick
Feb 12, 2015 | Washing Machines
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Nov 12, 2009 | Washing Machines
Can't open the kick plate of my samsung j845 washing machine
Happened to me too today. As I was pulling the handle, a piece inside snapped. The handle felt loose, as though it wasn't pulling the catch. To get the door open, I used a screwdriver. I pulled the handle as far out as I could, so that I could get the screwdriver in. The dark black metal part has to be levered away from the washing machine - in the direction the door would open. That will release the catch and then the door will open.
After the door is open, the challenge is to remove the handle. You'll need to undo all 10 (or so - from memory) of the little screws, so that the inner part of the door comes off. Be careful as you get to the last one - things will fall away. The handle and the small broken tab just fell out for me. Once the handle is out, you can put the door back together again. I use a small hex key to help open (and close) the door. With no handle, the catch springs a bit too far over for the door to close, so you'll need something (e.g. 1/8" hex key) to hold it over a little. So now, I can use the washing machine while I try to find a new part.
Apr 11, 2009 | Washing Machines
Washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 14, 2008 | Hotpoint WF430 Front Load Washer
Good luck
Dec 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
CDA CI392 Front Load Washer Logo
152 people viewed this question
Top CDA Washing Machines Experts
NOEL
NOEL
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
