Question about Nikon D50 Digital Camera
Nikon d50 i get over exsposure on the bright areas or the picture and this flashes white what do i need to do to stop this
    Novelist:
  • 148 Answers
The flashing means that the exposure is not correct for that area. if that area was the subject, then you might want to adjust the settings to reduce sensitivity in order to view that area correctly. if you spot meter the 'true subject' in the frame, there will often be areas outside that subject that are either brighter or more dimly lit. but exposure will be right for the subject. it can't all be correctly exposed if there is much variation in lighting. fill flashes will provide more light to the subject, thus resulting in a reduction in sensitivity of the resulting settings. (shorter exposure time or smaller aperture or a combination of both) and that will let the brighter areas move closer to 'not washing out' or being over exposed as some people refer to it. in either approach, its not a defect or problem unless it bothers you. the flashing just lets you know that you can modify settings if it matters that the photograph has high levels of contrast beyond what you may want. sometimes the subject is not in the center, and thus not metered for. but the framing is set to include something off to the side. you can reset exposure by adjusting exposure compensation so that while you are reading a darker area than that of the subject, you don't want the camera to use that area for light settings necessarily.
recap: exposure control via exposure compensation or fill flash
mark
Posted on Dec 22, 2007
When in playback mode, black patches flash on the screen, only in white areas. Actual pictures are not affected once uploaded and printed but its a very annoying problem! Nikon D50
You're seeing blown-out highlights. These are the portions of your picture that have been so overexposed that they've gone pure white, losing all details. This is generally considered a bad thing, but as the camera doesn't know whether you're deliberately going for that effect, it's merely warning you. The proper fix is to reduce exposure (the easiest way is by using exposure compensation) so as to bring back the lost details. This runs the risk of losing details in the shadows as they go pure black, but this generally isn't as bad as losing details in the highlights. We don't expect to see things in the dark, after all.
That was the long answer. The short answer is to repeatedly press up/down on the multiselector to choose a different view of your picture.
Jan 25, 2011 | Nikon D50 Digital Camera
How do you remove the white areas of a shot from flashing black when you look at the image?
What you're seeing is blown-out highlights. These are areas of your picture where the bright stuff (highlights) have been so overexposed (blown-out) that all detail has been lost. That's not necessarily a bad thing, but usually is. The proper fix is to reduce exposure slightly. Lost details in the dark areas are usually considered more acceptable than lost details in the bright areas.
If you simply don't want to see the blinking black/white parts of your picture, simply press up/down on the multiselector to select a different view of your picture.
Apr 25, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
Jul 27, 2009 | Nikon D50 Digital Camera
MY NIKON D50 SCREEN HAS THE WHITE AREAS OF PICTURES FLASH BLACK AND WHITE
Jul 21, 2009 | Nikon D50 Digital Camera
Nikon D50 : how do I ensure the flash will fire on day shots?
Auto mode only allows for "Auto Flash", "Auto Flash with red eye" or "Forced Flash Off". Forced, flash "ON" does not exist in Auto.
Put it into "P" for programmable mode. Then press the flash button on the left-face. The flash will pop-up. While holding the button, turn the selector dial to select what you want the flash to do - the little flash icons will display on the top panel as you do this.
Cheers.
Jun 08, 2009 | Nikon D50 Digital Camera
White areas flash in black
Go into the menu and check to see if "Mirror" is turned ON - if it is set it to "OFF"
Mar 26, 2009 | Nikon D80 Digital Camera with 18-135mm...
When I view my photographs on my Nikon D50 the white on the photograph pulsates with black where the white areas are on the picture. The photographs itself is perfect but this is annoying. Can you help...
You're looking at the blown-out highlights. These are areas where you've lost all detail. Press up/down on the multiselector to change the view. Better yet, reduce the exposure to reduce/eliminate them.
Aug 10, 2008 | Nikon Cameras
Nikon D40 - Flashing black on the light/white areas of inside & outside pics
It sounds as if you have changed the viewing setting so that the camera highlights over-exposed/highlight areas of the image.
While playing back images, press the multi-selector (4 way cursor) up or down to cycle through the various options.
This should be explained on page 51 of the cameras manual.
Hope this helps.
Matt.
Mar 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
AF area mode problem
To answer your flash question...the Nikon flash system fires the flash when the camera thinks the picture will be too contrasty without the flash. You can Google for "fill flash" to learn more. This is usually beneficial; if not, holding the flash button and turning the main dial will cycle through flash options on the top screen.
Jul 17, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
