Question about Nikon D80 Digital Camera with 18-135mm Lens
After press shutter? the err on display? mirrror move, shutter open-close
SOURCE: D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Posted on Feb 25, 2008
  • 19 Answers
SOURCE: Nikon D70 Err
The "ERR" code usually refers to an aperture problem. For example, if a lens with an aperture ring (Sigma is a favourite) used for earlier cameras is used, the aperture has to be set to its smallest (usually f/22 or "A" for automatic).
As you are using an 18-200, I assume it's the Nikkor VR. Callinto a camera store and ask them to check with a different lens. It may be the VR lens is faulty.
Posted on Apr 05, 2008
SOURCE: nikon d40
I had exactly the same problem, i tried everything,battery out, sd card out , lens off etc...nothing worked.Completely by chance and irritation i repeatedly pressed the shutter butten over and over
( without the lens attached ) till it didn't react at all.On my LCD i got a normal menu so i put the lens on and bingo it was fixed, still works fine.I think maybe the shutter was out of alignment.
Hope this works for you.
Olly
Posted on Jun 01, 2008
SOURCE: "Err" appear in the viewfinder and LCD display
i have a Orite Mv 3115-Real Dv Mpeg4Vga resolution 30 FPS Digital Veidio Camera. no the problem that the battery of my camera down and i sent that with my friend to bay a new for me unfortunatly he miss that on travel so i need to fins a new battery for that
i hope sir you can healp me to find one and a charger too
Posted on Feb 15, 2009
  • 421 Answers
SOURCE: nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Posted on Jan 17, 2010
Nikon d80 camera shows err error, when shutter is pressed the amount of shots remaining, shows er07. shutter works, but no picture is taken. Bracketing sign is also on display and wont go off.l
failure of the aperture unit is the usual cause - usually the contacts for the phase switch have come loose from the gear. You can find info on this by searching for the problem on the internet, including how to repair it.
Apr 06, 2013 | Nikon D80 Digital Camera
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
Hi i have dropped my d50 and err comes up
There is a motor/gear assembly inside the camera that moves the lens in and out and covers the lens when it is retracted. When it dropped, you most likely cracked or shifted something out of place. A broken tooth does not stop function, but shudders when it hits the gap. A shifted gear, slips and similarly may cause this effect. If it doesn't open the shudder, you get no picture.
You will need to open it up and attempt to repair the mechanics that drive the lens.
May 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Error blink in place of shutter indicator
I AM SAGHA REPAIRER FROM MUMBAI I THINK THERE ARE PLENTY OF REASONS SHOWING ERR ON TOP DISPLAY BUT IF ERR IS SHOWING JUST BY TOUCHING THE SHUTTER RELEASE BUTTON THEN THE MAIN BOARD IS DEFECTIVE.IF ANY MECHANICAL ACTION OCCURS AFTER PRESSING SHUTTER RELEASE BUTTON AND THEN ERR APPEARS THEN THE FAULT COULD BE OF SHUTTER & APERTURE BLOCK.I THINK ALL THESE SOLUTIONS ARE FOR EXPERTS AND NOT FOR GENERAL USERS IF ANYBODY FINDS THEM USEFUL LET ME KNOW & ALL THESE ARE BASED ON MY OBSERVATION ABOUT FAULTY CAMERAS.
May 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter stuck half open
This sounds like the mechanism has worn. It is a straight forward service centre procedure, I wouldn't recommend trying to do anything that will make it worse. Leave it to Nikons engineers.
Mar 11, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Feb 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
(http://photonotes.org/articles/oily-shutter/).
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
Feb 27, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Getting "busy" display on all modes except no-flash mode...
The "Busy" code will be on when the camera trys to use a flash and waiting for its charging action. Upon completion of charging the mechanism returns a signal to the camera to fire the shutter.
That means now your camera has something wrong on the flash unit and the camera waits for some certain time frame to finally determine it cannot complete a photo-taking command.
An "ERR 99" denotes that this kind of error has not been encorded explicitly and needs investigation services.
Dec 17, 2007 | Canon Digital Rebel / EOS-300D Digital...
Nikon D70 Err
Sounds like the shutter is sticking. This could be due to damage or just need cleaning. This probably means that you need to get the camera professionally serviced/fixed as shutters are extremely delicate.
Nov 09, 2007 | Nikon D70s Digital Camera with 18-200mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
22 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
