Home | Krups | XP 1500 Espresso Machine & Coffee Maker | Froth control problems
Krups XP 1500 Espresso Machine & Coffee Maker
Problem for Krups XP 1500 Espresso Machine & Coffee Maker
By taobuckets on Dec 22, 2007
I have an older Krups II Caffe Duomo type 985.  Coffee brew function works OK.
When brewing espresso, the brew function works OK, but the frothing control knob does not seem to work correctly.  Steam comes out at the same time the brew function is filling the espresso caraffe.  I can shut the frothing off completely, but cannot shut off the brew discharge.  as a result, there is no way to froth milk.
This is a new set of symptoms that started after I ran a cup of white distilled vinegar through it to remove any hard water deposits.
Same Problem
Feb 16, 2009
-   Ive bought this product and to tell the truth never really used it before. I just realized that the frth machine doesnt work at all. Ive followed all the instruction and no steam or hit comes out of it. Can anybody help...-   anapaulacota
Best Solution
posted on Sep 22, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Popular Solutions for Krups XP 1500 Espresso Machine
Questions and Unsolved Problems for Krups XP 1500 Espresso Machine
Do you recommend Krups XP 1500 Espresso Machine & Coffee Maker?
Answer
Answer
Hi, I just purchased the Krups XP1500 Coffee and Espresso Combi Machine. The coffee side works... (More)
Answer
I fill the 2-cup thing full to almost the rim, then mash it in using the circle on the end of the... (More)
Answer
My coffee and filter are in place, the water is in, the bottom gets very hot....but no coffee... (More)
Answer
how do you assemble the axle and the filter holder into the xp1500 expresso and coffee maker?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Krups XP 1500 Espresso Machine...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
