Machine doesn't spin or drain with full load - Washing Machines
    Problem Solver:
  • 12 Answers
Do you have small children? Sometimes a baby sock gets past the filter and becomes clogged in the small spinner that allows the suction to begin to drain the tank. I had this issue twice in the past. I had to unplug the device and take off the front cover. My washer at the time had the spinner located in the bottom of the drum on the front side gladly, and I dissasembled it. Lo and behold, a tiny white sock was in there (with some loose change). Once I removed it, and re-assembled it, it worked fine. Cost? nothing. I called a repair person to ask about it in general, and they told me about 50.00 to just come out, not counting labor. Check for small items/socks etc...
Posted on Oct 05, 2009
Doesn't spin
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
Apr 29, 2012 | Kenmore Washing Machines
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
GE frontload washer doesn't spin
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Water doesn't drain
heatman101
Aug 08, 2011 | Whirlpool Washing Machines
I have a MW511, it doesn't drain it just makes a humming noise
heatman101
Jul 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
Machine doesn’t spin,
heatman101
Oct 10, 2010 | GE WDSR2080D Top Load Washer
Washer doesn`t spin
heatman101
Oct 04, 2010 | GE Profile WPRE6100G Top Load Washer
I have stacked washer dryer. It runs, spins but it doesn;t drain. What may be the probable cause?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | GE WSM2420T Top Load Stacked Washer /...
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
