Question about LG LRG30355 Gas Range
Left rear burner ignites and burns well from a cold start but when restarting from hot it produces just a tiny single flame. Any suggestions?
  • 120 Answers
Sounds like a clogged orafice. I guess those LG aren't trouble free after all.
Posted on Oct 05, 2009
Gas hot water heater ignites and the burner flame cones up to bottom of tank then within seconds it starts to flutter and doesnt burn correctly. It's like it drops down and burns iracticaly.
Don't know how old your hot water heater is. They don't last forever. If the tank starts to leak inside the cone it will cause the burner to do this because the water droplets will boil and splatter. Only other thing to cause this is with a cold start up when the tank is full of cold water during high humidity.
Jul 04, 2017 | Water Water Heaters
Why does it start, then shut down followed by 3 clicks?
  • Thermostat calls for heat
  • Venter motor starts
  • Air switch verifies vacuum
  • Igniter sparks, or glows - depending on furnace
  • Flame starts in burner
  • Flame rod senses flame
  • Burner continues to burn until thermostat stops calling for heat
By your description, I would polish your flame rod, it will be a metal rod that is insulated from the bracket that is screwed to the furnace case and it will have a single wire attached to flame rod,
Sep 29, 2015 | Intertherm 56000 Btu Gas Furnace
Left burner produces a normal blue flame, but the right burner produces a big yellow flame - how can I fix this?
Hi inomura...
Look at the left burner, pipe,air hole adjustment,etc because it is operating good.
You will see a difference to it compared to the on the right.
The right pipe, air hole, or the length the pipe that are iserted in the gas control valve is different from the left.
The yellow flame indicates that not enough air is getting to the flame getting to the right flame ignition point.
The left flame is nice and blue...normal, the right is yellow indicating that not enough air is getting to the flame ignition point...look to see if the air hole adjustment is different than the one on the left...there is something open more or less, improperly adjusted.
Once you have it adjusted properly the right flame will burn bright blue just as it does on the left.
Please take time to rate me
Sep 04, 2011 | Coleman Roadtrip Grill LXE 9949-750
Turn up t-stat, circ fan runs, hot surface igniter glows burner lights blows warm for a short time and then goes cold, flashes 1 flash, ignition problem, no flame when acting up. model# DGAA070BDTB.
The thermocouple lets the control know the flame is burning, and if it doesn't sense flame it shuts off just what you describe. Sounds as though you need to replace the thermocouple.
Nov 11, 2010 | Heating & Cooling
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
What is pilot light?
A pilot light is the Flame that runs constantly, when any Gas appliance is operated, it is there always burning, very small flame, that is used to "Ignite" the main burners in the device.
Feb 21, 2010 | 3d Rose Hot Air Balloons - Hot Air Balloon...
Gas burners will not ignite ater cleaning stove top
hi friend,
On stove top burners that have sparklers that are not visible at the burner head, the burner heads have ignition ports. If the sparklers are functioning and the burners won't lite, chances are the ignition ports are clogged or restricted.
Ignition ports are tiny holes up one side of the burner head. If these holes are restricted, they must be cleared out. Cleaning can be accomplished using one of three methods.
Most commonly, a large sewing straight pin needle can be used. DO NOT enlarge the ignition holes. Doing so will have adverse burner lighting effects.
Burner heads where the flames will not burn completely around the entire circumference of the burner head, the holes which do not have flames are clogged up and need cleaning.
In cases of extremely dirty burner heads, soaking the burners in very hot water with plenty of dissolved automatic dishwasher detergent for several hours, rinsing and drying or a combination of both methods for heavily soiled burners.
hope this helps u
thank u for using fixya
please rate me..................
regards
sivaranjini
Sep 12, 2009 | GE Kitchen Ranges
Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
May 27, 2009 | Endless Summer Blue Rhino 235000...
The burners go out before the fan starts
Replace the flame sensor, clean the burners to ensure you have a good clean burn pattern and the flame is properly reaching the flame sensor.
Look for a flashing LED and determine what the failure code is.
Dec 05, 2008 | Heating & Cooling
Right oven 2 burner natural gas.burners stay on for 20 seconds.
Looks like something is blocking the burners from the insides.. My mom has fixed a similar problem of my neighbor yesterday...the solution is to disassemble the burners and clean it thoroughly and put them back on..
Good Luck!
Eagle.
Apr 12, 2008 | Kitchen Ranges
LG LRG30355 Gas Range Logo
59 people viewed this question
Top LG Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Steven Clarke
Steven Clarke
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
