Question about Sony Cyber-shot DSC-T70 Digital Camera
Same cammera, same problem
And I don't know how to solve it.
Someone can help us?
  • angelrogo Oct 05, 2009
    I mean, DSC-T70 shaking after turn-on.
Night vision camera dark
IF VIDEO WAS OK AT SOME PONT IN PAST, THEN CAMMERA BUILT IN ILLUMINATOR HAS GONE BAD (LIGHT BULBS BURN OUT YA KNOW)
IF VIDEO WAS NEVER GOOD FROM START YOU HAVE ASKED TOO SMALL A ILUMINATOR TO ILUMINATE TOO LARGE AN AREA , ADD MORE ILUMINATION TO AREA OR REDUCE OBJECT RANGE THAT CAMMERA TRIES TO SEE
Feb 25, 2014 | Lorex 4 Channel Business & Home Security...
My laptop shut down when on cammera after 3 minuts
In which case the webcam is faulty or your USB controller has failed. You could try and re-install the webcam drivers.
Apr 25, 2013 | Ema mb.n5402.001 - Emachines E525-2200...
I want to help solve problems but don't know how to reply i'm lost
  • My Products
  • My Friends
    On the left hand side of your home screen when you log (as seen above) just click unsolved and all the questions for you answer come up then just answer and post. Hope this helps.
Sep 22, 2012 | Computers & Internet
My phone wont ring everthing is turned up
Turn it off and then on. If no joy, turn off again, take battery out, put back in and turn on. Check your default ring (it could be set to "nothing," then volume won't help). Call your cell provider if they provide this model. They should know quickly what to do. If they don't solve it in 20 minutes, ask to "escalate the call." Don't be surprised if you get transferred (to someone smarter).
Feb 22, 2012 | Samsung Cell Phones
Where can I find a manual book of DVR74s in german? maybe I can download it? thankds for helping me
You can search on line for the mannual with the manufacturer of the cammera they will provide you with the mannual in different lenguages or if they dont have it in german they can refer you to the ppl in tech support with wherever issues you got with u cammera now you don put the brand if you put the brand somebody maybe me can send you a link for it
Aug 20, 2011 | Cameras
A friend bought a nec cammera on our holiday and
Need more info...where were they downloaded to?...a folder, my pictures, or a software program?
Feb 11, 2010 | Cameras
Night Time Pics
Hello Ruby, On the mode dial you will see a setting for night time use, you should not have to change any other settings. If you refer to the user manual it will explain this in greater detail than I have room here to list.
Best Regards, Russell
May 08, 2009 | Kodak EasyShare DX7590 Digital Camera
Camera has different problems
Ok, these cammeras seem to have a lot of problems. My suggestion is to seriously look on ebay or ecost.com and buy a new cammera to fit your cammera housing but if you are dead set on repairing yours then i would say open up the cammera body and there is a card on the front you need to replace. I would try the large card on the front of the cammera next to the lense first by the vauge description you gave. this seems to control all the processing. you may want to try a couple of simple things first like using a different memory card or replacing the batter inside the cammera. I don't know how a bad battery would effect the cammera operation but it is possible it could cause problems. If this doesn't help then take the cammera appart. REMOVE THE BATTERIES! REMOVE THE MEMORY CARD! THERE IS A CAPACITOR INSIDE THAT WILL SHOCK YOU, DON'T TOUCH THE CIRUIT CARD ON THE FRONT WITH OUT DISCHARGING THIS CAPACITOR!!!!!!!!!!
remove the screw around the outside except for the battery compartment and the retainer screws holding in the screw tripod mount. They can stay in. next lift the bottom of the back cover up and hinge it slightly forward. not too far. then carefully pull the top of the back cover away being careful not to shear off the top plastic snap in pieces or hinge it forward and break them! do not pull it off quickly because there is a ribbon cable holding in the back. Back off the ribbon cable retainer clip and remove the ribbon cable from the socket. This should remove the backing. Next remove the newly exposed screws and remove the ribbon cabble for the shutter switch the same way. then pull off the front cover carefully. let it hang by the micophone wires and what not and you will see the board on the front next to the lense with the capacitor that shocked you... Didn't I tell you to watch out for that! now tell your wife you were shocked incase your heart stops... next discharge the capacitor the rest of the way with a piece of wire. it should be the solder joints with the big re and black wires next to the lense. Then un screw the board and unplug the wires for it. remove the board and look for serial numbers. Look the numbers up on the internet or on ebay and try to find someone who is selling it for cheap. This is nearly impossible to repair and must be replaced. if you cant find a replacement, call olympus and ask for a replacement board. they will then tell you they dont sell them so lie and tell them you are a repair shop or alternately ask to speak to their repair department or a certified repair shop. call them and ask if they have the part and usually they are more helpful. Ask how much it costs and then realize that it is almost the same ammount as buying a new cammera. get mad and look some more on ebay for the part. once you find it... order it, install it, test it, and email me back and let me know if it worked at Lucient_lost@msn.com Also be carefull not to shear off the switch on the botom for the memory card door. It is very fragile. if you do there is a fix for it already on this web sight. I wrote that one too. If you have any more trouble with it email me. if something is unclear, email me and I'll call you.
Jun 21, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Future not supported error message on opening Camera
please formate ur mobile if problem not solve then change ur cammera.
Jun 18, 2008 | Nokia 3230
Tuch screen not working
the connection of the control button of the lcd panel is cut....check the flex wire of the lcd
Jul 19, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Cyber-shot DSC-T70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
