Question about Danby DDW2406 Stainless Steel Built-in Dishwasher
Danby error code 002
How do I fix error 002
  • jodi_la Jan 03, 2008
    about 5 minutes into a cycle i get this error code and have no idea what the problem is or how to fix it
  • handyhusband Feb 02, 2008
    Same problem. Dishes appear to be clean and displays error code 002.
    I noticed that the soap dispenser had not released and so manually released the soap. After the wash, dishes were clean but error code 002 was displayed.
    There was a little bit of water left over at the bottom. I checked filters and all appear to be clean (accessible ones anyway)
I spoke with Danby, and this error indicates the fact that the dishwasher is unable to fully drain. Likely causes are a kink in the hose, hose is too high on the drain pipe to drain, or, the pump motor is dying.
Seeing as mine's been mounted without fault in the same place for 2 years, I think I can tell you which one I have.
Posted on Aug 25, 2008
  • jhuh ijiji Oct 09, 2010
    I had the same code and after reading this I looked and there was a kink.
Error code of E-002-0000 canon printer IR 2002
Here is a link that I hope addresses the fix you need by the error if is an issue with the temperature of the fixing unit
Aug 24, 2016 | Canon Office Equipment & Supplies
How can i fix the error code 000001-00002
Assuming you have a copier or laser printer, this site:
Thread Canon IR 2200 error E000001 002
Some errors can just come up and you can just clear them and if everything works fine you don't need to worry about calling a tech. However if clearing it doesn't make the error message go away or you have problems emerge with the copier then you do have a problem.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Jan 11, 2016 | Canon Office Equipment & Supplies
What is the error e225-002 on a faxphone L100 ?
Can't find exactly the error, but e225 indicates in internal error...unfortunately the 002 indicates exactly where the error is occurring and can't find that indicated anywhere.
Found a few suggestions that a firmware update can fix a number of e225 errors. Firmware can be download directly from the Canon website here.
Canon Support Drivers FAXPHONE L100
Failing that, Canon's direct support number is 800-652-2666
Hope that helps in some way, and good luck!
Jun 17, 2014 | Canon FAXPHONE L100
Error code #4 on ddw1899wp danby dishwasher
see this possibles causes:
you must read your instruction manual and go to the section troubleshooting for fix it the error codes. If you do not have go or www.
God bless you
May 25, 2012 | Danby Dishwashers
Canon ir 3300 error code E000805-002
Oct 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
E006-002 error
...error code E006-002...there's a broken connection between the machine and the fixing unit as the front door is close...try to see the wiring from the fixing unit to the machine...or see the wiring in the fixing unit...
Jul 09, 2009 | Canon Office Equipment & Supplies
E3 error code on danby dhcc6020, its new out of box. tried danby service rep. , cant get a response back from them. any ideas on how to fix?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I had called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Danby Service Rep. helped me with my question about my P1 code (for DDR657EE).
Apr 11, 2009 | Danby DHCC6020 Dehumidifier
Error code E00012-002
If I recall correctly, e12 is a jam code. Power the unit off and look in user serviceable areas for paper bits. inspect sensors for paper bits. reseat external finisher unit. power back on. you may have a bad paper sensor in the unit.
Feb 19, 2009 | Canon imageRUNNER 2200
Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Jul 13, 2008 | Danby DWC513BLS Wine Cooler
Danby DDW2406 Stainless Steel Built-in Dishwasher Logo
857 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
