Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
Corrupted Rundll.exe My drive won't install; it keeps saying my rundll.exe has been corrupted. What do I do to fix it?
  • 330 Answers
Right click on mycomputer .....>manage...>device manger ...>(ur flash drive detect there but its comes in yellow mark) ...> right click on that and update the driver and givr the path C:\WINDOWS\inf
Posted on Oct 05, 2009
My windows xp no longer supports the system 32 rundII.exe connections
The rundll.exe is a critical core system file. If it has been corrupted then entire Windows is severely affected and it's too late to fix it. Make a backup of all your files while you still can and reinstall.
May 17, 2011 | Dell OptiPlex GX620 PC Desktop
What does "RUNDLL Error loading newdev.dll" and
newdev.dll is the Windows file that is responsible with the recognition of the hardware and the loading of the drivers - an absolutely critical file. This file is severely corrupted and the only way to fix that is to perform a Repair install.
Dec 15, 2010 | Dell Computer Refurbished OPTIPLEX SX270...
Rundll 32.exe
hello
Download Rundll.32.exe Repair Tool
Compatible: Windows 98, 2000, ME, XP, Vista, 7 (32/64)
How Do I Fix "Rundll.32.exe"? (Instructions) Please follow the following 3 steps to eliminate your problem:
STEP 1: dicon.png Download the repair tool
STEP 2: Install and open the tool
STEP 3: Scan & repair the found errors
please rate my service
Nov 18, 2010 | Computers & Internet
Everytime I start up Windows I an error message.
Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
How do i remove run.dll2 from my computer?
Rundll.exe files are programs that are directly tied to the registry on Windows computers. Dynamic Link Library (DLL) files contain libraries of information used by other programs running on your computer. They were originally created in order to help computer programs run faster on the Windows operating system. When a DLL file is corrupt or missing, a Rundll error will be generated. Normally when a rundll error is generated it is related to malware.
  1. Note the process that is generating the Rundll error by examining the last file name in the error that ends in ".dll."
  2. Open the service configuration program on your computer by selecting the "Start" menu and typing "command" in the search text field. At the DOS prompt type "services:msc" and click "Enter."
  3. Select the DLL service from Step 1. Right click the service name followed by the "Stop" menu button. Exit the service configuration program.
  4. Open your computer's registry editor by typing "regedit" at the DOS prompt and navigate to the Rundll registry key by typing "Microsoft\Windows\CurrentVersion\Run" in the Search field.
  5. Select the registry key returned and in the value associated with the registry key, confirm it ends in the same DLL file name found in Step 1. If it does, single left click the value and Press the "Delete" key. Exit the registry editor.
  6. Restart your computer and the Rundll error will be corrected.
Save a tree.
Apr 28, 2010 | HP W19b LCD Monitor
Rundll32 exe-entry point not found the procedure entry point_except_handler3 could not be located in the dynamic link library vmsvcrt.dll
Just visit this site...
http://www.fix-all-dll-errors.com/vmsvcrt.dll/
this will help in case of missing or downloading dll's .
helped in my prob. :)
Jan 11, 2010 | Computers & Internet
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
336 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
