I have an old radio with a dial tuner that has stopped working. I've opened it up and found the thread that goes around the spindle is broken. I could replace that but I can't figure out the route the thread should take. Any helpers out there?? Thanks. It's A Roberts Radio. RM20. UK brand. Must be 20 years old at least.
  • 4,234 Answers
The thread is called teh dial-cord and should be replaceable even with a heavy carpet thread. You are correct in that the routing is critical. There should also be a spring on at least one end of the cord. If the cord has just broken, you should be able to see the current route and jsut follow that route with the replacement cord. Get the cord tight with some tension on the spring. The spring should be able to take up any slack that occurs if the thread stretches a bit.
Dan
Posted on Oct 05, 2009
Broken horizontal spindle for Singer 2250 where an how do I fit a new one?
There is a product on-line called the "Wonder Thread Guide" (made in USA). ** F&E Company, Montrose, CO 81403**
I used it to replace a broken thread spindle, it works by sliding a spindle over the stub of the broken one, so thread stand upright instead horizontally. It is MARKETED to eliminate tangling, twisting, breakage, etc. Functions on all sewing/embroidery / quilting machines.
Sandy34287
Aug 03, 2013 | Singer 2250 Tradition
Help Audiovox Onyx
Its because of the tall buildings and all the power around you breaking the signals.
Apr 23, 2013 | Audiovox Xm Onyx Sirius Xm Satellite Radio...
How do you rethread a vintage radio tuner indicator?
can you email me at sideline@suddenlink.net and send me some pictures if possible, model and name of unit, ill try to help you, bean in the old radio business for years, Matt
Oct 29, 2017 | Televison & Video
Broken thread spindle
drill a hole into the center of the broken spindle, use a tap (from a tap and die set) and get the broken bit out. Buy a new spindle and put it in.
Feb 25, 2013 | New Home Sewing Machines
Bottom thread on Juki DDL-5550 is coming up. Top thread seems to lie flat
Check your upper thread at the spool. I've had industrial machines randomly throw a loop around the spool holder spindle which is hidden under the spool itself.
Also check your threading guide to be absolutely certain you are threading it correctly. Also make sure needle/thread diameter are suitable for each other.
Good luck.
Dec 02, 2012 | Sewing Machines
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
Triton ivory 4 power dial keeps turning not turning off
It happened with mine, the dials each work differently on their spindles and my main power switch dial broke. If your careful you can switch the dials over (remove them from the cover and swap them around). This worked for me until now as it's broken a second time. So now I have to order a complete front cover assy for 21 pounds.
Hope this works.
Jan 16, 2011 | Home
Bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Sep 01, 2009 | Necchi 3537 Mechanical Sewing Machine
White 2037 Bobbin Filling
turn your thread 3 turns to the right, clockwise,
then pass theend of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Jun 14, 2008 | Sewing Machines
Elna threading and reverse instructions
Hi
I have a Primula 310
The reverse is located in the middle of the stitch length dial, you press in the button whilst you reverse.
When threading up any sewing machine make sure the foot is 'up' as this opens the tension disks and the thread goes between. when you lower the foot the discs close around the thread and add the tension.
Hope this helps
Oct 31, 2007 | Sewing Machines
205 people viewed this question
 Grubhead
Grubhead
