Question about Nikon D60 Digital Camera
Flash will not fire. Tried the reset not luck. Under Custom setting built in flash is grayed out. This option not available with current setting. It is in the Auto mode
  • kakima May 11, 2010
    The flash won't pop up, or won't fire when popped up?
SOURCE: Flash
Thanks, I reckon I'll just have to change from auto exposure to one of the preset ones.
Posted on Sep 18, 2007
SOURCE: Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Posted on Feb 12, 2009
  • 4 Answers
SOURCE: Flash has stopped working on my Nikon D40
There's a common problem in the flash arm. I found this link that shows a simple repair. If you use this and make the repair yourself, understand that you will void your warranty if you have one. Also, do not touch the bulb as you'll get oil on it, and don't touch the solder points on the wiring, you'll get zapped. http://www.vimeo.com/3141400
Posted on Nov 22, 2009
  • 102366 Answers
SOURCE: In the CUSTOM SETTING MENU,
Switch out of the point&shoot modes to one of the PSAM modes by turning the mode dial on the top left of the camera.
Posted on Nov 12, 2010
  • 102366 Answers
SOURCE: Shooting mode message this option is not available with current settings..some options like picture control are grayed out
Most of the options are not available in the automatic point-n-shoot modes. You need to switch to one of the advanced PSAM modes to gain access to these options.
If you're not too comfortable with the advanced modes, turn the mode dial to P. The Programmed Auto mode is just like the green Auto mode, except that you have the ability to override the camera and choose options like Picture Control.
Posted on Jul 23, 2012
Testimonial: "thank for the info really helped me alot :)"
SB-800 Stuck in REMOTE
http://www.nikonusa.com/fileuploads/pdfs/SB800_sellsheet_060425.pdf
hers the manual on cam look under trouble shooting im still cheaking into it also
Feb 08, 2008 | Nikon Speedlight SB-800 TTL Flash
Rebel T3i built-in flash does not fire
Most Canon DSLRs have a switch in the hot shoe (if you look under the spring plate in the hot shoe one one side there is usually a small white shaft sticking up from underneath the top cover). Sometimes because of spillage etc. this shaft sticks down and the camera thinks that there is an external flash installed so it won't operate the built in flash.
In your case I would be more suspicious of the flash board. Does the flash symbol in the viewfinder light up? When you fire the camera does the symbol go out but the flash doesn't fire? This is a pretty common sign of a bad flash board.
A third possibility would be a broken flash tube. Has the camera been impacted?
Put the camera's mode dial on 'P' and push the flash button on the side of the mount/front cover. Does the flash pop up? Does it fire now? On the P,A,S,M setting the flash fires all the time if it is popped up; if it is one the green rectangle or other setting it only fires if there is not enough light.
Finally reset the menu to factory default in case something is selected that is causing the flash not to fire.
Apr 30, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Panasonic Lumix DMC-FP3 Flash option not showing
Is flash set to Force Off? (page 36 user guide)
Have you tried to reset the camera? (page 21 user guide)
Ref: http://service.us.panasonic.com/OPERMANPDF/DMCFP3.PDF
Dec 18, 2012 | Panasonic Lumix DMC-FP3 Digital Camera
I have a Canon Digital EOS Rebel XT and the built-in flash no longer pops up when needed. This started happening after using a Canon speedlite, but then removing it. I've tried resetting everything, and...
In addition to resetting all the camera settings you should also choose the "clear all custom functions" option that is also available from the same menu. Once that's done. Put the camera in Full Auto mode and see if the issue is resolved.
Sai.
Oct 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Sb-600 and d80 sync, connecting, off camera..
  1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
  2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
  3. Set the flash mode to Master (do not set it as AA or A)
  4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
  5. On the D80, from custom settings menu, select Built-in-flash
  6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
  7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
  8. Set the channel to the same as in step 4
Now you are ready to use the remote off-camera flash.
Jan 24, 2009 | Nikon Speedlight SB-600 TTL Flash
Problem with the Flash Light of Nikon COOLPIX L12 Digital Camera
I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Cheers.
Sep 27, 2008 | Nikon COOLPIX L12 Digital Camera
I HAVE A NIKON D40X.I CANNOT GET THE BUILT IN FLASH TO WORK.IT IS IN AUTO MODE AND FLASH IS TURNED ON.IF I ATATCH AN EXTERIA FLASH IT FIRES EVERY TIME.I HAVE TRIED IT ON ALL THE OTHER MODES,IT DID FIRE...
In Auto mode the flash will only fire when the camera thinks it needs it.
Only in the PASM modes do you get to decide whether to use the flash or not.
Aug 27, 2008 | Nikon Cameras
AF area mode problem
To answer your flash question...the Nikon flash system fires the flash when the camera thinks the picture will be too contrasty without the flash. You can Google for "fill flash" to learn more. This is usually beneficial; if not, holding the flash button and turning the main dial will cycle through flash options on the top screen.
Jul 17, 2007 | Nikon D50 Digital Camera
Nikon D60 Digital Camera Logo
80 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
