Question about LG RU-52SZ30 52" Rear Projection Television
Replace lamp notice appearing on screen. The only noticeable imperfection on screen is very slight blue tinge on left hand side. Is this common can i purchase lamp and replace it myself or is an expensive dealer repair.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
You can purchase the lamp yourself and replace it yourself. The lamp is built to fail after about 3-5 years depending on how often you watch it. There are step by step directions in your user's manual. If you have lost or misplaced it, you can download it for free in PDF format on the LG website. The lamp usually are around $200.
Posted on Oct 13, 2009
I have a KDF 46E2000.About a half hr ago i was playing xbox and noticed the top of my screen turn red from one side to the other, 1/2 in down. The very bottom of my screen is tinted blue but very...
The Optical Block is causing the problem. It has been a common problem and Sony may still have a recall on it. You can check it a 1800-222-sony. If it is not still covered, I would expect to spend 800.00 to 900.00 for the assembly plus 250.00 labor for a professional to replace it.
I hope this helps,
Skyassoc
Dec 08, 2010 | Sony Grand WEGA KF60DX100 60" Rear...
Blue spot on screen
there are light filters at each of the 3 lcd panels in the optical engine with a coating on them that determine the color. one of them (most likely the blue) is burnt from the heat and needs replacement. it could also be the fly-eye lens (whick evenly distribute the light) has burned as well. either way, it's very involved to replace, if you can get the parts. it's easier to have it sent in to get repaired.
Jul 31, 2009 | Canon LV-LP11 Projector Lamp for LV-7345,...
LG rear projection colours out of alignment
I have a similar problem with an LG (except my red is the one that is fine) and was able to talk to a tech in some detail about it. The tech prefaced by saying that he had done a hundred or so of these with exactly the same issue. This is very common and the life span of rear projection televisions is not great. Having said that, plasmas and LCDs are also limited in life span mostly due to modern high performance gaming machines which shorten the lifespan of monitors both plasma and LCD alike.
From what I have gathered, this is not a problem that you can easliy sort out. (Of course they would say that though) It involves replacing the digital board which means soldering followed by aligning the lamps which requires quote a lot of expertise.
The part itself apparently costs around $200 Australian and the labour will vary for the cost of the technician but I was quoted that the labour was about the same cost as the part.
Not sure if I would call this solved but I hope it has been at least a little helpful.
May 26, 2009 | JVC AV-56P575 56" Rear Projection...
3m projector color issue!
the light polarizer on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you'll need to replace the whole optical engine.
Dec 15, 2008 | Office Equipment & Supplies
LP70+ image problems
the colorwheel is dirty and needs cleaning (or replacing), or the light tunnel is starting to collapse (and needs replacing).
Nov 06, 2008 | InFocus LP70+ Multimedia Projector
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Hitachi 46f500 screen messed up after welding on same circuit
If you did manual conv. You have to redo it when you replace the bad parts. Them being conv. ic's replace them and check 1/4 watt resistors that are low value right beneath amps. Careful not to solder any foil pads together or you will have major problems. Very common for do-it-yourselfers. Good luck, Russmann.
Jun 15, 2008 | Hitachi 46F500 46" Rear Projection...
Sony 3LCD rear projection ghosting
sorry to inform you my friend but a lamp wont fix your problem. i afraid you will need an optical assy. this part is fairly expensive
Sep 29, 2007 | Televison & Video
LG RU-52SZ30 52" Rear Projection Television Logo
143 people viewed this question
Computer Repairing
Computer Repairing
