Question about Canon i80 InkJet Printer
Cannon i80 - message Waste Ink Tank Full - Canon i80 InkJet Printer
    President:
  • 787 Answers
Follow this procedure:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Don't forged to replace the waste ink absorption pad.
Posted on Oct 05, 2009
  • dngbrooks Oct 07, 2010
    This solved the problem in those easy steps. Thank you.
"Waste ink tank almost full"
Here is the reset process. You need to carefully follow the steps for it to work. Not to defend Canon but without the waste ink counter you will at some point end up with ink leaking from the printer.
Waste Error Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
I hope this helps.
Mar 21, 2011 | Canon Office Equipment & Supplies
It falshes orange and it makes a raddling noise
This error is cauded when there is a issue with the waste ink tank, which in your case will have to be resetted. To do the same please follow the steps as provided in the below article:
http://tricks-collections.com/waste-ink-tank-full-reset-canon-i80/
Also you can visit the cannon website and it tells you in detail the meaning/resolution when the orange light flashes:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i80#ServiceAndSupport
Fo to section "Services and support" and there in the dialog bos type "orange light flshes and it will give you steps to follow.
Please let me know if you need any further information.
Jul 21, 2010 | Canon i80 InkJet Printer
Cannon ip90 waste ink tank is full
These is all that u need to do:
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
There's a lot of methods and choice on how to reset it and this is all my best to share to you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 15, 2009 | Canon PIXMA iP90 InkJet Printer
Waste ink absorber is full contact service center message
waste absorber full reset sequence for the I80.
1)Turn off the printer. Press and hold the Resume/Cancel and Power buttons at the same time.
2)Release the Resume/Cancel button. (continue to hold down the power button)
3)While continuing to hold down the power button press the Resume/Cancel button 3 times then release both buttons.
4)The LED should now be green. Press the Resume/Cancel button 4 times. The led should be green.
5) Turn the printer off and then back on. You should be good to go. Unfortunately when the tank gets completely full it will stop printing. The cost of repair however is more than the cost of replacement.
Jun 03, 2009 | Canon i80 InkJet Printer
Cannot find information on waste ink absorber for Canon i80
The waste ink absorber collects any spilt in from the head and stops it leaking out or sitting in the bottom of the printer casing. The printer is telling you that the one in yours in nearly full. You know have two options:
1. Replace the waste ink absorbers and reset the counter (will require taking the printer apart)
2. Reset the counter only (you run the risk of ink leaking out)
The waste ink absorber for the I80 can be got quite cheaply if you google about.
You can reset the counter by:
selectable.)
button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times.
Hope that helps
Nov 16, 2008 | Canon i80 InkJet Printer
WASTE INK FULL
You need to download and run a service reset program which will reset the service counter. Have a search online, but I bet the solution looks something like this (cue music):
http://www.fixyourownprinter.com/forums/printer/33821
Good luck...
Nov 13, 2007 | Canon i80 InkJet Printer
Canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Aug 03, 2007 | Cannon MULTIPASS C530 Printer
Canon i80 InkJet Printer Logo
391 people viewed this question
old marine
old marine
