Question about Rigel Optics 3250 Goggles
Unit will power on. after several minutes it will fade out as if it is losing power. If I turn it off and then back on it will power up, but not as bright and then fade back out. After several times turning it back on and off, it will get progressivly dimer each time. I have changed the batteries twice with fresh Duracells, with no luck. The IR illuminater works fine. The unit has never been abused.
  • msharak Oct 05, 2009
    If it was the internal power processer, would it still power up and run at all, or would it just not work at all?
    Thanks emissionwiz.
    Top Expert:
  • Rigel Optics Master
  • 78,257 Answers
U have a failure n the light amplifier circuit, there is nothing you can do about this other than have the unit sent out for repair, they don't sell the repair manuals or the parts to anyone but the authorized factory repair stations, check the user manual for a list of repair centers for the Goggles.
Posted on Oct 05, 2009
  • 921 Answers
Check for corrosion on spring coil or tabs if not that then it probably your internal power processors.
How do you know if a watch battery is fading. On some watches the second finger moves two seconds at a time but on one of my watches it is just losing time.
If it looses time and it has been like more than 2 or 3 yrs since replacing the battery it could be that the battery is loosing power. loosing time is a symptom of a fading battery power.
Mar 10, 2015 | Nixon Watches
Hi I have Panasonic camcorder hoc-hs700 when turn on camra after few second later message on screen hdd error occurred please turn off unit and on again I have done that several time .but not luck pl
Hello there .
Well according to a manual,
Sounds like the Hard Drive is faulty.
"ERROR OCCURRED. PLEASE TURN UNIT OFF, THEN TURN ON AGAIN." is displayed.
The unit has automatically detected an error. Restart
the unit by turning the power off and on.
The power will be turned off in about 1 minute if the
power is not turned off and on.
Repair is needed if it is repeatedly displayed even if it is restarted. Detach the power connected, contact consumer support. ( Do not attempt to repair the unit by yourself
So......why not try a FORMAT of the Hard disk drive which seems to be at fault....nothing to lose friend Worth a try !!!!
Page 142 of this manual http://service.us.panasonic.com/OPERMANPDF/HDCHS700-MUL.PDF
Sep 16, 2014 | Lands Phones
Power mixer loses power
What is the make and model of this unit so I can find a manual and schematic?
Mar 12, 2013 | Music
I have an RCA HD52W59 TV that will turn on and picture is fine for awhile, then it will fade to total black. Still has sound and does not power off. Nothing will show on screen, not even menu options....
Thats a deflection problem which is causing the CRTs to shut down during deflection loss. The deflection board will need replacement. You can get replacement deflection boards from www.tvrepairworld.com
Apr 23, 2011 | RCA HD52W59 HDTV Projection Television
Try to power up my GPS 60csx and the screen stays on for several seconds then fades out.
I would suggest that you try the following master reset and software
update.
Please be aware that if you have not used your gps for a while it will
take time to download fresh information.
With the unit switched off please press and hold QUIT + MENU + ZOOM OUT
+ POWER
You will lose any data stored on the unit so back your unit up first. I
would also suggest running the latest software update from the following
link, if you have not already done so http://www.garmin.com/support/download.jsp
Once all this is done please leave your unit with a clear view of the
sky and allow it to acquire a satellite fix. This may take time so
please be patient. Once you have a fix leave the unit for a further 40
minute to achieve a good almanac update.
Jun 28, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Have sound, lose picture. D52W23
sounds like a solder issue. try resoldering the Ics that are attached to heat sinks on the Board that has the flyback also resolder the flyback pin connections
Jun 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Rigel Optics 3250 Goggles Logo
77 people viewed this question
Top Rigel Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Rigel Optics Optic Expert? Answer questions, earn points and help others
