My son reset the router to the factory settings via the button at the rear of the router now I cannot access the internet any ideas how i fix this ?
    President:
  • 1,188 Answers
No problem! What you need to do is phone your Internet Service Provider (your DSL service provider) help line and ask them to provide you the router internet protocol (IP) settings.
In no time you will be surfing the internet again.
Posted on Oct 05, 2009
How can I get back to the factory default settings if I can not get a link between the router and the computer neither between the router and the internet modem...? The modem alone, works ok, but also, the...
What Brand Router do you have? If you want to reset to factory defaults, behind the router will be a small button a reset button, Push and hold that button for at least 5-10 seconds then let got this will reset the router back to factory defaults... and under the router must be a sticker where the Routers IP address should be indicated to access the GUI/Settings page.
Make sure that by trying to access the routers GUI or setting page that your are connected using Ethernet to be able to access the Routers GUI.
Once in the GUI settings Page check if the wireless radio is turned on to be able to access the router wireless to get connected to the internet.
I hope this helps.
Oct 09, 2012 | Computers & Internet
How to log in to router
Open an internet browser, in the address area type in 192.168.0.1 (this is the normal address used by the router). Once the router access screen appears try usinfg the factory default login USER = ADMIN, PASSWORD = MOTOROLA.
If this does not work you can try using the reset button on the rear of the router to reset it's setting to factory default settings and try the above method again.
NOTE: If you are unsure about anything you can also try asking your ISP how to access the router settings. (If you received the router from an ISP). Otherwise use the manual at this internet location for more information. http://www.midcocomm.com/_files/files/SBG6580.pdf
Feb 21, 2012 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
My router has internet access but does not have Wireless function, i.e. WLAN light is off. also, when I type 192.168.1.1, it says Server is busy. i could not connect to the router via the internet.
First, try unplugging it and plugging it back in. The router may be locked up. If that doesn't work, take a pen or paper clip and press the small reset button on the back of the router. This will reset the router back to factory settings. If after resetting the router you still have no wireless function and cannot access the router through a browser, it may be time for a new router.
Aug 09, 2011 | Linksys Wireless-G WRT54G Router
I cannot connect to the internet using my netgear n150 wireless router. The internet light is orange but the modem is working fine and I can connect to the router itself.
When the router is turned on, the Internet light turns amber for about 20 seconds and then turns green. If the light does not turn green, the router has a problem. If the Internet light is still amber 1 minute after turning on power to the router: a. The Internet is not accessible. Confirm that you have the correct internet setting. b. Clear the router's configuration to factory defaults. This will set the router's IP address to 192.168.1.1. c. Turn the power off and back on to see if the router recovers. If its still not working, reset to factory defaults. You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 4). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Jun 06, 2011 | Computers & Internet
Do not know know password for wireless internet
Hi
Go here and download the manual http://static.highspeedbackbone.net/pdf/Netgear-WNR2000-manual.pdf
You will need to reset the router or change the password in the router 1. To change the password, goto Internet Explorer 2. In the address bar type 192.168.1.1 3. Press enter key 4. YOu should see a box with username and password fields. 5. username is admin 6.password is password 7. These are not the wireless passwords but the access password to get in the router. 8. Once in the router interface on Internet Explorer; goto the wireless sections and change the password there.
To reset the router WARNING: This will reset all the settings to what it was like when it came fresh out of the box. You may need to know some other settings. Restoring the Default Password and Configuration Settings You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 5). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Failing this, please refer to the manual, page 29 onwards
All the best now
Phil
Dec 17, 2010 | NetGear WNR2000 Wireless Router
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
Cannot remember log in info
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 12, 2010 | Linksys WRT54G2 Wireless Router
The Cisco System logo just stays orange, I attempted to repair on my lap top but it won't let me repair.
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 09, 2010 | Linksys Wireless-G WRT54GS Router...
When my pc starts I get an error message concerning something missing in the dynamic link library. How do i fix this?
Try:
Resetting the Linksys Router to Factory Default
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 08, 2010 | Linksys Wireless-G WRT54G Router
I can not connect to the internet via my browsers (firefox and IE), i get bad request. When I directly connect my computer to the modem excluding the router I get access. Any ideas?
try to see if you can access the internet using ping Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type CMD a black box will appear in there type the following ping google.com if you get for replies then you can access the internet and your firewall maybe blocking the access try disabling the firewall. If you get no reply -then you need to look at the settings of the router you could do a factory reset of the router - button on the back of the router marked reset , hold the button - or using a untwisted paperclip in the hole - for 10secs The router will now be reset
Mar 10, 2010 | D-Link DIR-655 Wireless Router
Computers & Internet Logo
271 people viewed this question
David Payne
David Payne
