Question about HP Compaq nx9030 Notebook
How to remove black spots from compaq nx9030? There are 4 such spots of different sizes. Plz help. Thanks
    Guru:
  • 355 Answers
Service the display or change it in service center
Posted on Oct 05, 2009
Are there different head sizes for a tennis racket?
there are 3 different head sizes of rackets. here is an explanation of the different sizes from http://www.dummies.com/how-to/content/choosing-a-tennis-racquet.html
Over-sized:
Beginners really like the over-sized and even jumbo frames, which offer between 100 and a whopping 140 square inches of strung surface. Such frames give you a larger sweet spot simply because the hitting surface is bigger, and they allow you to hit the ball farther from the heart of the sweet spot and still make a good shot.
Mid-sized: These racquet heads range from 85 to 100 square inches. Most pro players use frames on the low side of mid-sized - between 85 and 95 square inches. Most recreational players gravitate to the high side of mid-sized - between 95 and 100 square inches. Mid-size racquets offer a great compromise between a larger strung surface and sweet spot and a maneuverable frame that lets you generate good racquet speed when you swing.
Standard-sized heads: Ranging from 80 to 85 square inches, standard-size heads are now obsolete. They give you a smaller strung surface and sweet spot, making it more difficult to produce crisp, clean shots.
Feb 20, 2013 | Sport & Outdoor - Others
My Compaq Computer Presario CQ61 Consumes Power But The Screen Stays Black?
I believe this may be due to a faulty screen lamp. You can replace this device it is located under the screen in the cavity just below the screen inside the plastic housing piece. You will have to remove the housing of the screen. This is done by removing the round rubber screw covers.
Carefully take a thin screwdriver flat head and pop the screen cover gently on one of the corners or look for a spot or slot to place a flat object in. Gently take plastic cover piece off. The lamps are different for each model, however they basically do the same thing. 4_21_2012_3_27_14_pm.jpg
This is the Housing Section your looking for. This is what your going to be replacing.
4_21_2012_3_30_47_pm.jpgThese are the various kinds of them. Here is what you will be replacing as well.
I hope that this assists you or gives you a better idea of what this repair is about.
John
Apr 21, 2012 | Computers & Internet
Hi i have a 1975 honda cb200..new plugs,points and timing set..new carb kits inc needles.tried different coil and condenser....great untill engine up to temp..then flat spot off tickover......also black...
Move the clip on the jet needle lower on the needle. This will help with the flat spot by giving fuel earlier. The black smoke is a rich fuel mixture. Check to see that the carb kit had stock jet sizes. Be sure to synchronize the carb slides so they both begin to lift at the same exact moment. tombones49_223.gif
Aug 08, 2011 | 1974 Honda CB 200
I got a black patch at left most corner of my laptop screen( in task bar zone) and it is gradually increasing, can u plz tell me d problem and way to rectify it.
Are you sure the screen is not cracked down there? It sounds an awfully lot like a cracked screen
dow there. Does it look sorta like the picture below (only in the corner)? Almost like an ink spot?
Dec 10, 2010 | Compaq Presario CQ60-220US PC Laptop
Problem related to the painted black surface
If it was just a cloth without any substance that would remove paint, then Yes, Call Tech support and let them know. They should/will have the issue corrected.
HP and Compaq products for Home & Home Office use
HP and Compaq products for Home & Home Office use 800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
800-HP invent
or
800-474-6836
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 08, 2009 | Computers & Internet
My computer compaq T242KPBZ0074 ...I want to download the video drivers and audio driver???? May i help me pLz....I install it now plz....
hI TRY THIS LINK TO DOWNLOAD YOUR DRIVERS.
http://www.driversdown.com
please rate if it solves your problem so that i can give you more option if it does not solve your problem.
thanks,
Jonags3
Apr 15, 2009 | HP Compaq Motherboard
Compaq presario r3000 laptop monitor problem
You have a bad LCD area on the monitor. You can replace it yourself or take it to a repair shop.
Mar 16, 2009 | Compaq Presario R3000 Notebook
Spotting on IBM R40 TFT Screen
you can get a screen replacement cheaply on ebay/craigslist
Aug 31, 2008 | IBM 11P836402 for ThinkPad R40 Monitor
My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
Apr 18, 2008 | HP Compaq nx9030 Notebook
HP Compaq nx9030 Notebook Logo
136 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
