Question about HP LaserJet 5n Printer
How to reset the printer menu - HP LaserJet 5n Printer
    Guru:
  • 355 Answers
Goto propertie find the option reset default
Posted on Oct 05, 2009
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
Reset factory settings
  1. Hello please try the below steps to reset the printer:
    1. Hold down the "Resume" button on your Canon printer for one to two minutes, and then release the button. In some instances, this may reset the printer automatically.
    2. Unplug the power cable from the back of the Canon printer if the printer did not reset when you held down the "Resume" button. Hold the power button down and plug the power cable back into the Canon printer. Do not release the power button.
    3. Press the "Resume" button on the Canon printer two times and release the Canon's power button. The Canon printer resets to the factory settings and the ink level should appear full.
    If you will need more help you can download the service manual for canon ip6000d from the below link:
    http://goo.gl/gAqyP
    Thank you
Jun 26, 2013 | Canon Pixma iP6000D InkJet Photo Printer
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
I have a Dell W5210n printer that I replaced the fuser on. How do you reset this printer?
1. Turn off the printer.
2. Press and hold (check) and .(right arrow).
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
5. Select Reset Maintenance Count from the Configuration menu.
6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset.
When the reset operation is complete, the menu returns to the Printer Setup Reset
Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press
Select to Return to Ready status.
(answer previously provided on fixya.com by ramrui)
Jan 04, 2010 | Dell 5110cn Laser Printer
How to reset maintenance counter on a Dell 5310
Jul 21, 2009 | Dell 5110cn Laser Printer
NEED TO RESET MAINTENANCE MESSAGE
Turn the printer off. Press and hold the select and return buttons while powering on the printer. Release the buttons when the display shows "Perform Self Test". The printer will continue to boot-up. When ready the display will show the word Config Menu. Then press the menu button untill you see the Reset Maintenance Count option. Then press the select button. The reset command shows on the second line of the menu. Press the select button again to reset. Now press the menu button untill you see the Exit menu and press select. The printer will now automatically reset itself and boot up ready to print.
Apr 26, 2009 | Office Equipment & Supplies
Lexmark x642e MPF Reset maintenance counter
Power printer off. When printer is powered off, hold down the check button and the right arrow button and hold these down while powering printer back on. Hold the buttons down for 10-20sec....
When printer is finished you are at the config menu. Hit down once, and you will see reset maint counter. Hit menu twice... and you will see resetting...
Then hit back twice to get to the main menu and use your up/down arrows until you see exit config menu. Hit enter and it will reboot printer back to the regular menu.
Feb 02, 2009 | Lexmark X642e All-In-One Laser Printer
Setting print count on Lexmark T644
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Dec 17, 2008 | Lexmark T644dtn Printer
HP LaserJet 5n Printer Logo
Seeker5211
Seeker5211
