Question about Dell Inspiron 6400 Notebook
I can't get my screen to come up. The machine is
I can't get my screen to come up. The machine is on, but I can't see anything. The monitor works. I'm wondering if I've locked something. There is a light on the lock key that has a '9' on it. Usually the WIFI light is on instead. Any ideas?
    Master:
    Sergeant:
  • 460 Answers
Pls incress the brightness of your monitor by monitor buttons.
Posted on Oct 05, 2009
The computer has a pink screen and wont do anything
Pink screen is usually either
Broken video cable to the monitor
Broken video card
Broken monitor
Try the machine with a different monitor cable and a different monitor. What happens?
In terms of troubleshooting can you provide more detail
What specifcally happens when you boot the machine up. Does it have a black screen that has typing on it which then changes to pink later? Do you see any writing at all while it is booting?
Does the hard drive make the usual noises during the startup?
Jun 24, 2014 | iBuyPower Extreme 915SLC Desktop 2.66GHz,...
I have a Dell Dimension e521 desktop that has gone into energy save mode after I ran Norton security check.. Pressing any key or clicking the mouse doesn't do anything. The screen is black and says...
you may find you have the screen resolution set to high, try changing to 1024x768 and try again. if this works it means your monitor ain't up to the job of your better machines.
Nov 15, 2013 | Cars & Trucks
Screen on my desk top monitor says its going into sleep mode cannot access safe mode monitor screen wont stay on long enough to do or see if anything works....,,, my pc is an hp a6500f , i replaced the...
Try using a different monitor or use that monitor on a different computer to see if the monitor is bad. It shouldn't have anything to do with your CMOS battery. I'd check to make sure the monitor itself is good before I go tearing my computer apart. Let me know how it goes and maybe we can get it figured out.
Aug 03, 2010 | E-Machines eMachines Desktop PC
When I connect the lcd to my laptop, the lad shows
hi atuire,
try hooking up the lcd screen toanother computer and if it shows the same double screen again then there is aomething wrong with your lcd monitor,
you may want to use another monitor with your laptop to ensure the problem is not on the laptop's side.
if issue stays same with another monitor, then just right-click onto desktop background, goto properties and have a look whether you have enabled the shared monitor feature
(meaning that u can use two screens with just one graphics card parallel, to work on a 'wider' range of sight.
Therefore your machine's graphics card sually must be equipped with both: a standard vga out and a HDMI-out as well.)
if your machine ddoes not have these capabilities but still the monitor sharing is turned on from the software side, this might cause the problem. To disable simply change the graphics card's
propertiers as descried above.
Good luck
Sep 06, 2009 | Gateway Computers & Internet
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Screen lites up but no display
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 26, 2008 | E-Machines E17T 17" Flat Panel LCD Monitor
Blank Monitor
hey maby the onboard van on it dont work well with yoru pci slow ok so unplug the onbord fan try again ok
Jan 21, 2008 | PNY Verto GeForce FX 5200, Graphic Card
AL 1916 Monitor Green Light Flashes
I think you have loose cabling somewhere. Try to unplug (and untangle) the video cables and then plug them all back together firmly. If this does not work and you know your machine is booting up properly, you might have damaged the monitor somehow accidentally.
Nov 16, 2007 | Gateway FPD2275W LCD Monitor
Monitor Screen Bright with horizontal white lines
I have an emachine 17" Flat Panel Monitor and I accidently touched the Standby Mode on my keyboard and now my menu won't work right. I can't adjust the color enough. If there is anything I can do to fix my problem it would be appreciated.
Thanks
Oct 08, 2006 | E-Machines 17F2 17" CRT Monitor
Dell Inspiron 6400 Notebook Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
