The computer restart after shutdown i cannot turn
The computer restart after shutdown i cannot turn off the cumputer without seperate the main cable of the computer
  • maortauz Oct 05, 2009
    what is smps?
    Guru:
  • 355 Answers
Change the smps then try again
Posted on Oct 05, 2009
  • 700 Answers
Maybe he means the entire power supply( It is where the SMPS). Also that could be BIOS problem. You can try to unplug and replugged the CMOS battery for about a minute. But this will restore factory default settings.
Or that could also be data corruption.
Posted on Oct 06, 2009
  • fougzki Oct 06, 2009
    Do this when unit is off and unplugged to wall socket.
The screen says no signal
If you have already verified the connection between your computer and the monitor you can try these steps to attempt to get an image on your monitor.
First, check your monitor for a button that says "source" or a button that has a square with an arrow pointing to the center. This will switch where your monitor looks for the signal.
A good rule to follow is if your monitor is connected to the computer by a cable with white ends, you should select "Digital", and if it is connected with a cable with blue ends, you should select "Analog" or "VGA". It is possible, but unlikely that your monitor is connected in any other way.
If these steps still do not work, follow these steps exactly:
  1. Press the windows logo key 220px-ctl_wndws_alt.jpg and "R" (This opens the "Run" window.
  2. Type this command: "shutdown /s /t 0" without the quotes. The shutdown command with the "/r" and "/t 0" switches tell shutdown to restart the computer at "time 0" which is immediately
  3. Wait for the computer to restart and it should automatically detect the correct display to use.
  4. If all else fails and you cannot get the display to connect, restart the computer and press "F8" until the computer comes up into safe mode. From there you can verify whether or not the monitor is actually functional, as driver incompatibility issues are not a problem when running in safe mode.
Nov 25, 2010 | Gateway FPD1975W 19" LCD Monitor
I shut down my computer to reboot it and when I went to turn it back on it would not go back on. Everything seems fine all the plugs are ok and the green power light is on.
u may be selected the standby mode in the shutdown option,press the power button it will power on quickly andthen shutdown properly.if u want to restart then select the RESTART option while shutdown.
Aug 15, 2008 | HP Computers & Internet
Tip
Create Shortcut for Shutdown / Hibernate / Restart
Right Click on the desktop
Goto New
click on Shortcut
Type location of the Item as "shutdown -s -t 5" Without quotes
Here Shutdown -s is the command to shutdown the computer and -t shows you the time in seconds before shutdown
Similarly you can create shortcuts for Restart by replacing the -s with -r and for hibernate simply replace it with a -h
note: you can change the delay timer as per your need
ENJOY !!!!
on Dec 03, 2009 | Computers & Internet
Computer suddenly shut down and won't restart
This type of shutdown problem occurs mainly due to following few reasons, 1) SMPS problem 2) RAM failure 3) Over heated mother board chip(s) or seldom over heated CPU 4) Virus or worm problem or OS problem. 5) Over heated power cords
Do the following steps one by one (to detect the exact source of problem) First replace the CMOS battery, change SMPS, check power cord, run the PC directly (without UPS), remove the data cable from hdd. if it runs well then set the data cable with hdd, if it does not work then definitely there is mother board/cpu problem. And if it creates same problem after fitting the data cable - change the hdd or format hdd and reinstall os. your problem would be solved.
Jun 05, 2010 | Gateway GT5465E Refurbished Intel Desktop...
System shutdown message pop up and shut down and restart computer
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
Jan 22, 2010 | Computers & Internet
Can not shutdown /CPU fan allways working
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Sep 30, 2009 | Abit SG-71 Motherboard
Usb problen
Check that the 1394 usb header is not plugged into a USB 2.0 PORT and these are the cables inside and should be marked on the mobo.Did you install this board? Is it factory or replacement?
Aug 08, 2009 | MSI 845GVM-L (MS-6714-040) Motherboard
Applications will not open
if you like to turn of your computer
then try this
--> pres window key + r
--> the run command dialog box appear
--> type "shutdown -s -t 10" without quotes if you like to shutdown
--> type "shutdown -r -t 10" if you like to restart
i hope when you restart your computer it will be fine.
Apr 02, 2009 | HP Pavilion dv6000z Notebook
My itoch makes my computer turn off
try using another data transfer cable,it seems there a short connection on your data cable.when this happens the pc will automatically shutdown and restart.if it still dont solve the problem then check the terminal of the itouch for a possible short circuit.
Dec 21, 2008 | Apple iPod touch
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
Computers & Internet Logo
272 people viewed this question
David Payne
David Payne
