Question about Drills
Do you know the output voltage of the charger for a Stanley 4.8v Screwdriver (63-048). I have three similar chargers but different output voltages.
  • 66 Answers
SOURCE: Makita DC18RA charger conversion
You can't use the same capacity as it gives you a very
large and expansive capacitor.
I used the max. diameter of 30mm that could go into the PCB of the model I have and it is 470uF 400V
You'll need to replace another capacitor, see my mod page !
This works !
I added another HowTo page for modding the DC18RA from 110V to 220V , you can find it here
all the components details are in it
Have fun and good luck
Posted on Jan 10, 2009
joboo1
  • 257 Answers
SOURCE: 18V cordless drill charger #981832-001
Hi again, Because of the age of these batteries, this may or may not work but you have nothing to lose. The theory here is that over time, oxides built little bridges in a ni cad battery between the anode and cathode thus shorting the battery, shocking the battery burns those bridges and if the cells are still intact it will work again. So take your stronger battery or cables and being sure to observe the correct polarity touch or brush the positive to positive and negative to negative several times. The first times will spark and then as the bridges burn the spark will decrease. Put the battery in the charger and the charge light should come on. Leave the battery in the charger until it reaches a full charge. If after this procedure you still have the defective indication, then the cells were bad and you will still have to replace the battery. Good luck, please let me know how this works for you!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 29, 2009
SOURCE: Charger is dead (UC12SD). I checked the fuse, it's
While the above advice is correct I curently have the same problem.
I have measured the secondary of the transformer and found it to be dead, no volts.
This transformer has a center tap that I guessing is 24v centre tapped. If any one has had any experience with this area would you please advise to eme@iinet.net.au
Thanks
Doug
Posted on Feb 23, 2010
SOURCE: Ryobi Model 1412001, 16vdc, 2A
Same thing was happening with my Ryobi 18V Nicad Charge + batteries. I boujght a 18V Chicago Electic quick charger from Harbor Freight tools, and just jumped the wires to the battery while monitoring the voltage with my meter. It started around 9v, and while the Ryobi Charger did nothing, the Chicago electric charger cycles on/off repeatedly till the voltage goes up to around 20 volts or so. At that time, I simply put the battery in the Ryobi Charger and it instantly went to the red "fast charging" mode. Seems it needs some decent battery in the battery before it will actually charge it. FYI. the charger from Harbor Freight #43933 cost me $4.95 !
Posted on Mar 06, 2010
jyackle5
  • 8197 Answers
SOURCE: My new Blackmax drill battery charger does not put
You can find a repair center on the link below. You just need to put your zip code in to find the nearest one to you.
http://www.blackmaxtools.com/customer_service/service_center_locator
Good Luck
Posted on Jun 13, 2010
Blackberry Charger / Sealed Lead Acid Battery
Depends mostly on the voltages and how long you want to wait, but you will have to accept the risk of frying the charger by exceeding the 700mA rating. If the voltage output of the charger is about 10 or 20% higher than the nominal voltage of the battery then it might be OK. If the output of the charger is less than or equal to the battery voltage, then it won't work at all. The smaller the differences in the voltages, the less the risk of overheating the charger, but the longer it will take. If you are in the "sweet spot" it will probably take 6 -8 hours to charge the battery.
Jun 21, 2012 | Toys
Hiya, does anyone know where i can get a charger for a R M z91fr laptop ??
If you can identify what the battery / laptop power requirements are, then you can buy replacement 'universal' laptop power supply / charger units which come with a selection of different standard connectors to plug the charger into the laptop.
Amazon sell a Sumvision Universal Laptop AC Charger Adapter which is available in different power output wattages (95V 120W). - you just need to select the correct DC output voltage by a switch selector and the correct connector for your laptop.
Jan 01, 2012 | Computers & Internet
I need to purchase a replacement charger for my CnMnotebook. Can you pelase advise where I can get one and what the price will be. Thank you Marion Forsythe
What's your part number of your original charger? The output of voltage and current? And your notebook model? Use this info, do a search in google, there will be many online stores selling this part.
Hope this may help.
And pay attention that:
Thefollowing three conditions should be met for you to use this charger safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Jan 05, 2011 | Computers & Internet
Battery is not charging when connected to charger
The problem might be in the battery or in the charger. If you have a multi-tester check the output voltage of the charger. The voltage output must go with the rated voltage in the battery. If there is output volyage in the charger then the problem is your battery. If there is no output voltage then the problem is your charger. Take time to check both the charger and the battery to make sure which to replace.
Dec 07, 2010 | LG Shine KE970 Cellular Phone
I have a Dell Inspirion 1525. The Battery would not charge and the light would flash orange. I bought a new one and upgraded from a 6 cell to a 9. Now it says plugged in but not charging and the batt light...
Firstly, i suggest you try to use the charger with a similar laptop to see if it will charge it.
If it does, it means the charger is still very much good.
And as for the battery you change, it will be better for you you to check the voltage rate on your charger and the voltage rate on the battery because it is very possible, the voltage rate of your charger might not be able to power your new battery.
The voltage of the new battery might be higher than what the battery could power, so you might need to get the same voltage rating of charger for the new battery.
**** you can still test the charger with a similar laptop to be sure the charger is still good.
Take care.
Apr 19, 2010 | Dell Inspiron 1525 Laptop
Inovix Portable DVD Player - have lost the charger
...first you must make sure the voltage of the player...usualy you can read it in the back panel of the player...example : 9 volt 500 ma....then after you know for sure the voltage you can find an universal charger with at least same output....at the electronic store...make sure you have a same voltage and miliampere !!!
Jul 09, 2009 | Televison & Video
Need to know voltage for charger. Have lots of
I have similar problem but for GE 86707? What DC output is required?
Jul 07, 2009 | GE Bluetooth In-ear Headset Wireless...
Does a laptop charger need a voltage regulator?
No. Your charger is designed to correct for input fluctuations and has a certain tolerances to meet for output voltage and current ripple.
Jun 17, 2009 | Compaq Computers & Internet
Drills Logo
138 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
