Question about Welding Tools
A red fault light is illuminated all the time it wont work
    Problem Solver:
  • 7 Answers
The 3 reasons which will cause the infamous red light of death to come on and the machine not function, is because of over/under voltage protection,( make sure you have adequate voltage to the machine) thermal protection (because the duty cycle was exceeded), or mosfet failure. Assuming you have the correct voltage, and the machine is cold, try opening the case. Attached to the aluminum heat sink housing the mosfet transistors is a small button sized metal pill with 2 wired attached to it. This is a bi-metallic thermal fuse, when it gets hot, the contact points inside will open up, and cause the machine to shut down. Check for continuity, because sometimes these contact points inside dont re-align correctly, and your machine thinks its always too hot. If you plug in the machine, and it seems to work, but when you key your plasma torch, everything shuts down and the red light comes on......then theres a good chance the mosfets are gone. When they go, there paired off in series of 3, Chances are youll need to change all 3. Hope this helps........
Posted on Jan 18, 2010
  • 2 more comments
  • Larry
    Larry Oct 21, 2010
    Too generalized stating mosfets, could be any number of other componets failed.
  • wadef Oct 23, 2010
    RE: (Too generalized stating mosfets, could be any number of other componets failed.)
    I agree Giant Tech, but for sake of brevity, and because i didnt feel like typing all night, blown mosfets are the most likely cause. I too have dealt with your old manufacturer, and have had MOSFET nightmares. Most were caused by poor assembly techniques,( either ESD Damaged chips, or over tightening of the retention bars that hold them in place), and caused them to crack.... Ive had about 10 machines,( From various manufacturers), in the past that when new mosfets were put in, they worked fine, for years. Any thing beyond blown mosfets, wouldnt be worth mentioning as repair now becomes beyond the scope of what the owner could repair himself..
    regards...
    . Wade
  • mwise70 Nov 15, 2010
    would the min air supply code show up
  • Polymetalfab Feb 25, 2011
    Wade you seem to know a great deal, maybe you have an answer for me. I have a 1251 the pc board that distributes power in the machine had a burned diode, it still cut fine. Now I have no pilot arc, the board looked burned worse than it did. I purchased the board and replaced it, still no pilot arc. No error lights and the air solenoid opens when I press the trigger. I also tried my barrel torch with its remote on/off switch. Still no pilot arc.
    Problem Solver:
  • 18 Answers
Hi, this could be the air pressure is not high enough or set too low try setting the correct bar pressure on the gauge to the recomended value which is on the spec plate or somewhere on the machine. Usually this is between 4 & 7 bar
Posted on Oct 07, 2009
LG 60PN6500 plasma tv power surged. has no picture and i think no sound. tv wont turn on but stand by light illuminates but then shuts off. in a cycle fashion. cant find my multi-meter to check fuses
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 20, 2017 | LG Televison & Video
97 Nissan quest wont start red security light blinking
The Security Indicator Light illuminates to indicate that the security system is either working properly or to let you know that there is a fault in the system.
If the Security Indicator Light is flashing with the key out of the ignition lock and accessory position, this is a normal sign that the alarm and the immobilizer system is active.
While starting the car or key in the "run" position, the security lamp should illuminate briefly then go out. This a "bulb check" and is also normal.
If the Security Indicator Light is on steady with the key in the "run" position, and the vehicle won't start, there could be a fault with the system. In this case, the first thing to try is a different key to see if this starts the vehicle. If it starts, the key is faulty or the system has a problem with that key. If you are still getting a no-start with the light on steady, the system is at fault and will need to be inspected.
Dec 14, 2016 | Nissan Cars & Trucks
Why does check engine light blink when I accelerate?
Hi Ced ,
The malfunction indicator lamp (MIL) is located in the instrument panel cluster. The MIL will display as either SERVICE ENGINE SOON or one of the following symbols when commanded ON:
Check engine ! The MIL indicates that an emissions related fault has occurred and vehicle service is required.
The following is a list of the modes of operation for the MIL:
The MIL illuminates when the ignition is turned ON, with the engine OFF. This is a bulb test to ensure the MIL is able to illuminate.
The MIL turns OFF after the engine is started if a diagnostic fault is not present.
The MIL remains illuminated after the engine is started if the control module detects a fault. A diagnostic trouble code (DTC) is stored any time the control module illuminates the MIL due to an emissions related fault. The MIL turns OFF after three consecutive ignition cycles in which a Test Passed has been reported for the diagnostic test that originally caused the MIL to illuminate.
The MIL flashes if the control module detects a misfire condition which could damage the catalytic converter.
When the MIL is illuminated and the engine stalls, the MIL will remain illuminated as long as the ignition is ON.
When the MIL is not illuminated and the engine stalls, the MIL will not illuminate until the ignition is cycled OFF and then ON.
Trip
Mar 13, 2015 | 2003 Chevrolet Impala
My Tristar TV signal booster has a red light illuminated, I think is says 'short' above it. Is the booster working? I have fault on my TV it maybe this. The booster has been working fine up till...
I too have a red "short" light on my Tristar booster. However- I've illiminated the Tristar as I unplugged it and connected my tv directly to the 13amp mains and b) connected the aerial directly to the aerial wall socket which is separately boosted from a distribution amplifier box in the loft. Picture was U/S so the "short" is probably in my cabling in the loft (I've been moving the aerial about lately).Hence I suggest initially to unplug the Tristar and check the fault is not back further up the line ie the cable and booster at top of house. Hope that all makes sense.ps before noticing the red "fault" light, my picture had gone to pot.
Jul 18, 2011 | Televison & Video
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
When trigger is pulled, no red light blinks. Model has power
there is illumination board problem. replace it and your scanner working properly the illumination board which three lights on its top.
Apr 07, 2010 | Metrologic Instruments MS1690 Handheld
Outside electrical outlet does not have power however when switch to outlet is in on position red light illuminates but no power,tried reset buttons and checked for flipped circuits
If the power light illuminates when the switch is on ,you must at least have a 'live' feed.
If nothing works when plugged in, it tends to suggest that there is a break in the 'neutral' somewere or that the neutral contact in the switch is not activating.
You need to get a multimetee and test for volts across the line and neutral with the switch on, if you get no reading you have a neutral fault.
Finding the fault will not be easy as it will be a faulty outlet, a bad connection or worse but unlikely a broken wire.
Dec 16, 2009 | Electronics - Others
My Dual XDM7510 display quit working and I can't find out what is wrong. Everything else on the XDM7510 works. Help me please. It was working when I went in the store came back out and no display.
try checking the illumination light on the back of the radio if that doesnt work then try looking at the red ignitionswitch wire and make sure it is connected to the 12vt constant (the yellow wire)
Mar 10, 2009 | Dual Car Audio & Video
Constant Red Light on Control Panel Circuit Board
The red light under the cover of the humidistat is fault light. This light typically indicates that there is an issue with your connection at the two wiring terminals labeled ODT on the humidistat. I would recommend checking to confirm that there is something currently connected to the two terminals. As a side note these two terminals can not be jumped out with a jumper, and must utilize either the outdoor temperature sensor (part 8052) or the manual mode resistor (part 4336).
Dec 08, 2007 | Aprilaire 400 Humidifier
Welding Tools Logo
2,078 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
